Question about HP Computers & Internet
How to lnstall a psp ctf file - HP Computers & Internet
Posted by zubairpashto on
Vipin Kakkar
    Mentor:
    An expert who has written 3 tips or uploaded 2 video tips.
  • 251 Answers
Hi
1. Download the plugin
2. Extract the file and place into root of your MS0:/
3. Put the theme file (any name you like :)) under MS0:/PSP/THEME/
4. Enable cxmb.prx in Recovery (under VSH)
5. Go to Settings -> Theme Settings -> Theme to select your CTF themes
6. System will reboot to take effect
7. Also notice that you will at least need PSP FIRMWARE 3.90 OR HIGHER to be installed on your PSP in order to get these themes running... Or see the video
http://www.google.co.in/search?q=to+install+a+psp+ctf+file&hl=en&safe=off&sa=G&prmd=ivns&source=univ&tbs=vid:1&tbo=u&ei=L2YxTf_TCIzEvgObvpSqCw&oi=video_result_group&ct=title&resnum=4&ved=0CCIQqwQwAw
google_protectAndRun("ads_core.google_render_ad", google_handleError, google_render_ad);
See the video
Posted on Jan 15, 2011
.ctf file and .ptf file
A .ptf file needs to be flashed to the psp's internal memory. You need custom firmware in order to do it and there is a slight chance you can brick the psp.
Jan 15, 2009 | Sony PlayStation Portable (PSP) Console
Cannot apply ptf themes on psp
you have CFW? if so, turn off cxmb.. you have OFW make sure your firmware is 3.70+
Dec 16, 2008 | Sony PlayStation Portable (PSP) Console
Psp slim 4.01 M33-2 ctf themes not working.
hey dude.. dis is miguel jalandoni from philippines.. i also had dat problem.. but.. i realized something.. i noticed dat there are different cxmb's and der are specific ctf's for each... maybe ur ctf's aren't for the cxmb ur using.. wat i did was i got packed themes.. i downloaded it and when i opened the folder.. it was complete.. cxmb, plugin, and themes... use that cxmb and put the themes and those themes from that folder will all work :D hope i helpwd :D
Nov 10, 2008 | Sony PlayStation Portable (PSP) Console
The theme problem
1.Download CXMB for 3.90 off this website
2.Connect your PSP to the computer
3.From the file you just downloaded go to CXMB_for_3.90>CXMB_FULL and take sepluginscxmb and ._seplugins and put them in the root of your Memory Stick
4.Go to recovery menu and enable the cxmb.prx plugin
USING CXMB
1.Download a CTF file off from the internet somewhere
3.Drag the CTF file you download and put it in X:/PSP/THEME
4.Go to SETTINGS>THEME SETTINGS>THEME then select a theme that you have put on your PSP  and press X then press X on apply
5.Your PSP will restart and the theme you chose will be on your PSP
Oct 26, 2008 | Sony PlayStation Portable (PSP) Console
I need help
To use the .CTF Themes you need to download the plugin called cxmb.prx
1. Download the plugin (cxmb.prx)
To Use the .PTF Themes download it first then put it inside ms:/PSP/THEME. if the folder is not there please create it. To apply the theme on your PSP, go to “Settings” => “Theme Settings” => “Theme”.
Oct 24, 2008 | Sony PlayStation Portable (PSP) Console
Ctf file wont work on my psp. but the site where i got my ctf file theme says that it works on psp 3.71 m33 version. my psp is 3.71 m33 version. why does it not work? what will i do?
you can try to check your ctf file using another psp,and see if it'll work.if it doesn't then the ctf file is the problem,you need to download and re-install it again,see how it goes.if still no dice,i suggest you try to look for other similar files to use on your psp.or you might want to upgrade your psp to 3.90 m33-2 at least to enjoy more options as far as themes is concerned especially the custom XMB themes (cxmb).if you have time you can check this channel: http://www.youtube.com/user/kr2008 .no guarantees,hope this helps.
May 05, 2008 | Sony PlayStation Portable (PSP) Console
Ctf file does not work
you go on google and search "PSP themes" then find on eyou like. extract the theme with WinRAR or other extracting program and open the folder. connect your PSP to PC via a USB cable. go to settings>USB mode. open PSP and there should be a themes folder. copy / drag the .ctf file into theme. disconnect, then go to settings > theme settings > theme, then pick your theme from the list. since your running 3.71 M33, you may or may not have the ability to apply themes.
Apr 30, 2008 | Sony PlayStation Portable (PSP) Console
Open Questions:
Computers & Internet Logo
76 people viewed this question
Top HP Computers & Internet Experts
Lee Hodgson
Lee Hodgson
Muntejaya Ginting
Muntejaya Ginting
efs_perpends
efs_perpends
Are you a HP Computer and Internet Expert? Answer questions, earn points and help others
