Question about Konica Minolta Bizhub C300 All-In-One Printer
Bizhub C300 error C8103 - Konica Minolta Bizhub C300 All-In-One Printer
just me
    New Friend:
  • 60 Answers
To improve paper-feeding in the paper take-up section of the document feeder some adjustments have been newly made. Please ask a technician for this updates, but the error code suggest binding in the lift motor (may need to be replaced) or the lift plate is not producing enough pressure.
Posted on Feb 25, 2011
How to rest a C3452 error code on a minolta C300
try a trouble reset turn the machine off hold utility/counter power machine on select trouble reset reboot machine
Aug 17, 2014 | Konica Minolta Bizhub C300 All-In-One...
Malfunction detected, please call Tech Rep. C8103
there is a 8301 but no 8103 for a Bizhub 350
Btw, I’m available to help over the phone in case u need at https://www.6ya.com/expert/normanj_7893313f0751935f
Feb 13, 2014 | Konica Minolta bizhub 350 All-In-One Laser...
Bizhub c300 white stripes
clean the print head glasses
Jan 30, 2014 | Konica Minolta Bizhub C300 All-In-One...
Konica minolta c300 error c2555
replace the yellow image unit
Nov 25, 2013 | Konica Minolta Bizhub C300 All-In-One...
How to configure bizhub c300
can you check the protocal settings in printer properties
Dec 28, 2011 | Konica Minolta Bizhub C300 All-In-One...
When I turn on the machine (bizhub c300) error code c3452 appears, within 20 secs, How do I reset this code
This is a fuser related code.
To reset the code, please do the following
1. Turn OFF the Main Power Switch.
2. Turn Main Power Switch ON while pressing the Utility/Counter key.
3. Touch Trouble Reset.
4. Check to make sure that OK is displayed and the it has been reset.
5. After turning off the Main Power Switch, turn it on again more than 10 seconds after
and check if the machine starts correctly.
Good luck
Jan 21, 2010 | Konica Minolta Bizhub C300 All-In-One...
Konica Minolta Bizhub C300 All-In-One Printer Logo
2,110 people viewed this question
Top Konica Minolta Office Equipment & Supplies Experts
Norman  J Weimar Jr
Norman J Weimar Jr
carpediemweb
Level 1 Expert
George Mclaughlin
Are you a Konica Minolta Office Equipment and Supply Expert? Answer questions, earn points and help others
