If
you want to listen your TV on your Stereo system thru your receiver,
** you need to connect "Audio Output " RCA jacks or "Optic cable output" of your TV ** to "AUX input "
or "Any input" of your receiver ( except Phone ) or "Optic Cable input" ** than just switch to
respective mode on RECEIVER corresponding your RCA or Optic connection... There you go..Your TV sound is on the Receiver..
Take care and please Remember to rate/vote and give me 4 Thumbs Up for Helping out the Community :) Hope this helps!
The Wii AV cable should have a red/white pair of Audio Output jacks on it.
Check out pg. 8 of the Wii manual:
http://www.nintendo.com/consumer/downloads/WiiOpMn_setup.pdf
Connect the red/white RCA plugs from the AV cable to a line level audio input on your receiver. If you use AUX IN, then select AUX IN on the INPUT selector switch. You should then hear the sound from the Wii through your receiver/home theater system.
thats no surprise. even though they say that the remotes that come with receivers are universal, usually they will only control a very limited device list. good luck
the rxv463 will not upconvert any video signals. its what they call a pass thru video switch. chances are you are using a red, white. yellow (composite) connection. you will then need to pass this yellow thru the receiver to the yellow output of the receiver and into the yellow input on the tv. the same rule would apply to the component inputs and outputs as well as the hdmis
the trick is, it has NOTHING to do with your receiver, and EVERYTHING to do with your TV, you need to choose SAP on the TV not the stereo. That will send the SAP sound to the stereo you are playing the sound through.
"I am also having difficulties in try to display the yamaha set up menu on the tv." According to the manual the display menu for TV will not work with HDMI hook up. I also have a Panasonic HD TV and can't get TV sound through my Yamaha AVR on "TV Sound" mode. Trying to use HDMI cable for this also. Do I need a digital optical cable or do I not have something set right?
What you will need is a phono pre-amp, then you can run into the receiver with a line level input to an empty audio input on the receiver, you can try Radio Shack to obtain one.
