Question about Carrier Heating & Cooling
What is leaking? If it is water, you need to find the drain pipe leading from the inside unit to the outside of the house, and open up the obstruction in it. You could push a wire up through it, or send some compressed air up it. The drain pipe is probably near the ground next to the foundation or in the ceiling of an outside porch.
If this is a window unit leaking water you need to clean the obstruction out of the drain pipe or hole on the outside of the window, probably at the bottom outside rear of the unit.
I wasn't sure from your question if it is leaking water, or leaking refrigerant gas. If it's the gas you probably need to call an A/C repair service.
good luck,
genetuck
Posted on Jan 15, 2011
