Samsung RS2534 Side by Side Refrigerator Logo
Question about Samsung RS2534 Side by Side Refrigerator
I moved my rs2534ww ref. and after i pluged it back in it now only flashing one bar on the ref temp readout and its not running or cooling (in the move it was never laid down)
Posted by mikefra on
Anonymous
    New Friend:
  • 9 Answers
I found a repair manual on the online auction place E b a y. you may want to look there for a service manual that can help you through the controls of the refrigerator. On mine i press and hold the top 2 buttons and it will reset. It also does a diagnostic and if one light is flashing then it is telling you there is a problem with your samsung. Look for the manual it may help.
Posted on Jan 29, 2011
The cooling power lights on my samsung fride freezer keep flashing and the fridge is not keeping cool so my foodstuff keeps going off
NOTE: This
is a multi-solution answer since I don't have all the tech from your question to pinpoint your problem
But the solution is in here generically, if you read and study the solutions very,very carefully.
First I would check cold control. Thats where you turn it off, if your temp is not warm. it can
be defective and not shutting off. If your temp is warm proceed with the following.
I would check the fan in the freezer. Listen to see if it is running
It moves air to the ref from the freezer
Then check to see if FREEZER CONTROL is turned WARMER WHICH MAKES THE REF COLDER AND VICE-VERSA. SEE?
The ref. temp should be about 33-35
The Freezer temp should be 0 to 10 Any thing below these temps is overkill and a waste of elect
The higher the number you turn it up to is the coldest
But is probably a common defrost problem The ice build up
is not being melted by the defrost system.The fan can't blow through the coils into the fridge.
Take out back panel of freezer to check for ice buildup. The coils should be clean.
There are three components to a defrost system- a heater,heater thermostat, and a timer unless you have a defrost electronic card.
Its best handled by a Technician but you could possibly do it by taking your model number to the nearest appliance parts store and asking for the parts. They are mostly located in freezer ,behind back panel on freezer coils.except the card which is usually located in ref The parts store will have info
Also check fan undernearh Ref in the rear
Clean condenser coils underneath
Make sure back cover is on the fridge. Some take them off and throw them away.
make one out of cardboard if its gone, using the holes of the old one.
.I'm including my article on Refrigerator Repair for your help and convenience.;
Please click or copy and paste into browser for Article
http://www.fixya.com/support/r5816737-fix_refrigerator_psychologically
If
you need more help go here:
http://www.applianceaid.com/procedures.html
MORE
TIPS AND TRICKS:
STOP PAYING FOR EXPENSIVE WATER FILTERS FOR YOUR REF. DO THIS====
http://www.fixya.com/support/r9962087-stop_paying_high_price_refrigerator
WATER SPLASHING IN FREEZER AT ICEMAKER
THE FILL TUBE IN BACK OF REFRIGERATOR CAN SLIP
AGAINST THE FILL RESERVOIR CAUSING A PARTIAL BLOCKAGE
OR BECOME CLOGGED WITH ICE.
REMOVE THE ICEMAKER AND INSPECT THE FILL TUBE.
RUN WATER IN TUBE TO ELININATE BLOCKAGE AND CHECK
TEMP IN FREEZER. IF TEMP IS BELOW 0 DEGREES, THATS
OVERKILL AND USUALLY A WASTE OF ELECTRICITY TO KEEP IT THAT COLD, NOT TO MENTION THE FILL TUBE FREEZING UP
Thanks for using fixya
Leo Ponder
imufo2
Please VOTE FOR ME AND GIVE ME YOUR TESTIMONIAL IF POSSIBLE, IF THIS WAS HELPFUL
ITWILL BE MUCH APPRECIATED.
Rm2620 panel control lights are flashing if the temp selected is above level 2. At level 3 and above the on, auto, gas and temp indicator lamp flashes, I hear a click at each flash and if the door is open...
NOTE: This
If
MORE
TIPS AND TRICKS:
Leo Ponder
imufo2
I have a Samsung refrigerator model number rs257barb. After a power outage my fridge stopped cooling to cool temperatures. It would only cool to lowest 75. The weird thing is the freezer side was still...
NOTE: This
If
MORE
TIPS AND TRICKS:
Leo Ponder
imufo2
4yr old refrigerator freezer freezer works fine refrigerator barly cooling have to turn to 6 or 7 still barely cooling
NOTE: This
If
MORE
TIPS AND TRICKS:
Leo Ponder
imufo2
My defy f350 freezer most of the times stoops cooling.first we suggested of changing the pc board and it worked for 2weeks.now the alarm light keeps flashing again.as atechnician am stuck now.
NOTE: This
If
MORE
TIPS AND TRICKS:
Leo Ponder
imufo2
My Whirlpool EL7ATRRKQ01 ALL REFRIGERATOR cools but it doesn't seem to ever shut off. No matter where I move the temperature dial, I can hear the fan going all the time. The only time it shuts off is...
First I would check cold control. Thats where you turn it off, if your temp is not warm. it seems
to be defective and not shutting off. If your temp is warm proceed with the following.
Then check to see if freezer control is turned WARMER, which makes the Ref. colder
Also this might be a common Defrost problem, Ice
Check cold control (thats where you turn it colder)
Leo Ponder
imufo2
Please VOTE FOR ME If this was helpful
2helpful
2answers
Changing temp readout on Midea Air Con Controller from F to C
  1. Make sure the unit is NOT on lock mode
  2. Press reset button for 2 second or until the Flashinf "F" appear on the temperature display or panel.
  3. Press Add button to change from Fahrenheit"F" to celius "C".
  4. Then press confirm and then cancel button to finish.
4helpful
Samsung Cool Tech Dynamic not cooling properly
Alan if the power was off for less than 5 minutes the compressor high pressure went to the low side and the compressor just will not start. The thermal overload Klixon will click about every 8 or 9 minutes and the compressor will not start.
Unplug it for about 30 minutes and then plug it back to see if it lites off and runs correctly.
As for the control panel... (fingers crossed) hopefully it is a symtom of the compressor not starting. Again unplug it for 30 minues and restart it after that. It just may get things back to normal without any repair service.
Freezer and ice maker quit working / The temp.display on the door is just flashing .
There may be a fan that moves cold air in the freezer and icemaker compartment(s).  If the fan freezes up the cold air will not circulate.  Since the fridge compartment is still cold it does not sound like a compressor problem.
14helpful
In my side by side samsung RS2534WW the rerigerator is warm
I read elsewhere that if you hold the power cool and power freeze buttons down for 12 seconds it will restart the system. I did it the other day (because we were having the same issues) and it has seemed to work for the last few weeks. Frige temp stays at 34F and freezer temp stays at -2F
Top Samsung Refrigerators Experts
Marvin
Marvin
Steve
Are you a Samsung Refrigerator Expert? Answer questions, earn points and help others
