Toys Logo
Question about Lionel Toys
I recently purchased a Dash 9-44 CW Diesel locomotive. It has on the label of the box "Command Equipped" - "Towercom TM" - "Crewtalk TM" - "Railsounds TM". My question is - WILL THIS LOCOMOTIVE WORK WITH A CW-80 80 WATT TRANSFORMER AND OPERATE THE Railsound, Crewtalk, Towercom and Smoke? I was told when I purchased the locomotive that all of this would still work. Just not all the dialog. But none of the Towercom, Crewtalk or smoke will operate. Is that because this locomotive requires a Legacy Remote Control System?
Posted by dnfrost7 on
Traindoc
    New Friend:
  • 38 Answers
I'm not familiar with the Dash 9-44 CW but it may be that the sound and smoke switches are turned off. You will probably find these under a removable cover on top of the locomotive or under it, usually near the cab. Check your instructions or go to Lionel.com and click on support. Instructions and manuals can be found here.
Posted on May 03, 2017
5 Related Answers
bobkelsey
  • 46 Answers
SOURCE: WHISTLE STOPPED WORKING on CW-80
replace the button with a new one just remember which wire goes to which terminal. you will need a soldering iron and electronic solder to do this trick , also make sure you un plug the transformer. by any chance you got any n-scale trains you want to get rid of . If you do send me the info @ [email protected] I'am a disabled veteran with little funds.
Posted on Dec 01, 2008
Anonymous
SOURCE: lionel CW - 80 transformer
Check out this link, I think it will help.
http://www.lionel.com/media/servicedocuments/71-4198-251.pdf
Posted on Jan 20, 2009
tbreeze47
Tom Carson
  • 3083 Answers
SOURCE: Why does my new CW 80 transformer show constant
It sounds like the variable resistor control is faulty or shorted, and supplying voltage all the time. If the unit's new, enforce your warranty or exchange priviledge. This problem shouldn't be happening for a few years.
If, for some reason, your warranty doesn't apply, you'll have to take it apart to figure out what's broken or shorted.
I would contact Lionel, if worse comes to worse- maybe they would send you an exchange.
Here's their support site:
Good luck, and hope this helps.
Posted on Nov 18, 2010
Anonymous
  • 2418 Answers
SOURCE: The Cw 80 watt transformer
If you have a volt meter you can check the rails for power, Check the transformer wiring to the first rail connection and then along the rails for loss loose connection(s). If you have power to the rails it is an issue with the Engine, Check any brush or rail riders (connections) for a bent or broken tab. If for a temp fix in a broken connection tab or brush you can use Tin foil. Hope this helps.
Posted on Dec 25, 2010
condega5
  • 4 Answers
SOURCE: Can I use the cw-80 transformer on any Lionel
You should be able to. The Lionel transformers all put out AC power, not DC and many Marx and American Flyer transformers will work too. The real question is total amount of power being drawn and whether or not you have the wattage to match your engine and accessories. With the CW-80 though, it should put out plenty. I run my pre-war 1666E engine pulling a full compliment of metal cars with no problems using a CW-80.
Posted on Feb 10, 2011
Will the Lionel lion chief remote work with the Thomas and friends train and transformer?
Thomas & Friends Diesel Locomotive with LionChief Remote System ... LionChief locomotives can also run on any track powered by a conventional transformer ...
3answers
Have a t250 diesel need to know what fuse for 12 volt outlet on dash
1st look in owners book that came with the vehicle. It will be listed in a picture.
Vacumn line routing for 97 dodge 5.9ltr Cummins diesel 4X4
VACUUM DIAGRAMS
By law, each vehicle is equipped with a Vehicle Emission Control Information (VECI) label which is permanently affixed. On the models covered in this guide, the label will be found in the engine compartment with typical locations being on the underside of the hood, the top of the radiator, the alternator bracket and the air cleaner box.
The VECI label provides a vacuum schematic for the vehicle in question. Because vacuum circuits will vary based on year, various engine and vehicle options, always refer first to the vehicle emission control information label.
VECI labels are designed to be permanently attached to the vehicle and cannot be removed without being destroyed. Absence of the label in your vehicle may indicate undocumented repair work has been performed.
If you wish to obtain a replacement emissions label, most manufacturers make the labels available for purchase.
How does a diesel electric locomotive work?
Diesel oil is ignited in cylinders of diesel motor which turns a generator, which powers electric motors connected to wheel axles.
1helpful
User Manual download
Get onlineand got to www.google.com In the google search box type: "AcerSupport" (without the quotes and put your manufacturer name before Support). Look for downloads and drivers. Enter your model number and operatingsystem when requested. Look for Manuals on the site.
TM 4201WLMi user manual download
Get onlineand got to www.google.com In the google search box type: "AcerSupport" (without the quotes and put your manufacturer name before Support). Look for downloads and drivers. Enter your model number and operatingsystem when requested. Look for Manuals on the website.
I am using a standard 80 watt transformer (not command control), but the rail sounds do not work on this unit at all. I have checked the on/off switch and played with the volume, but still no sounds. At...
Many of the MTH Protosounds 1 and 2 and Trainmaster will not work with the Lionel CW-80 electronic power source. The output waveform is so non-like sinusoidal. The electronic sound systems will not usually respond to this waveform and when they do, the sound will be garbled. Use another power source.
My Vizio blu-ray player works just fine for regular dvds, but when I put blu-ray in, it reads "no disc".
Make sure the disks you are trying to play are the same region code that your blu-ray player is set for.
If there is no issue with the region setting, and you recently purchased the player, return it immediately because the blue laser transceiver is not working.
If you bought it "someplace else" check the labels..... there is a common "burn" where normal DVD players are being sold with blu-ray boxing and labels. I even heard of a person getting a box of bricks!
Every time I print it suddenly stops in the middle of printing and says "error".
hi there
the only one i could find is TM-U220 , which falls under the TM-U200 series, as stated in this link.. i i advise you to get in contact with Epson directly , as they are the only ones who can assist you with this issue..
I hope this serves you well
http://pos.epson.com/products/TM-U220.htm
http://pos.epson.com/developers/index.htm
Top Lionel Toys Experts
Marvin
Marvin
Paul Bade
Are you a Lionel Toy Expert? Answer questions, earn points and help others
