SOURCE: Re: CanoScan LIDE 30 on Mac OS X (Version 10.5.6)
I was able to install the CanoScan Toolbox by doing the following: MacIntosh HD --> Library --> CFMSupport --> Get Info. Under 'Sharing & Permissions', I added my name & changed 'Read only' to 'Read & Write' .
Problem now: I can't install the LIDE 30 Scanner Driver. I clicked on the downloaded driver & a box opened. I clicked on ScanGear CS Installer, but that didn't work. I then clicked on 'Into Plug-In' --> ScanGear CS 7.0X --> Choose Application --> CanoScan Toolbox 4.1 --> Plug-Ins, but couldn't continue as the 'Open' tab was greyed out. What should I try? Any suggestions would be appreciated.
SOURCE: CanoScan N 650U drivers
this is to canon website for the driver
http://www.usa.canon.com/consumer/controller?act=ModelInfoAct&tabact=DownloadDetailTabAct&fcategoryid=351&modelid=6858
If you need further help, reach me via phone at https://www.6ya.com/expert/david_eb7ea98642566cc6
SOURCE: Canoscan Lide 600F I can't
target disc means hard drive or other disc that the file temporary loads to. its either full or most like write protected. right click on the scanner in control panel or the scanners. select "where" to save to in the popup menus
SOURCE: lost canoscan D1250U2 installation disc
Visit Canon Official Support
Select the operating system (XP) and download the drivers and scanning software.
GoodLuck!
Dont forget to appreciate the solution if I could have been of any help!
CreativeTECH
SOURCE: I have windows 7 professional
1. Click the link below, select [ Save ], specify "SaveAs", then click [ Save ] to download the file. Memo : If you select [ Run ] ( or [ Open ] ) instead of [ Save ],the file will be automatically installed after it is saved. http://gdlp01.c-wss.com/gds/6/0900002986/02/3200fvst8511a_xpen.exe 2. The downloaded file will be saved in the specified placein the self-extracting form ( .exe format ). 3. Double-click the downloaded EXE file to decompress it,then installation will start automatically.
