Jwin JD-VD140 DVD Player Logo
Anonymous Posted on Jan 14, 2011
I have a jwin jd-vd140 dvd player and the power light keeps on blinking and nothing works too. What can I do?
aravind shet
Level 2:
Filmmaker:
Uploaded 5 video answers.
  • Expert 141 Answers
  • Posted on Jan 14, 2011
aravind shet
Expert
Level 2:
Filmmaker:
Answers
141
Questions
0
Helped
45199
Points
479
Did you tryed dvd head cleaner disc? try it . and keep smiling
  • Anonymous Jan 14, 2011
    DVD player does not work. DVD tray doesn't open and I do nothing. Another help?
  • aravind shet
    aravind shet Jan 15, 2011
    pull the power plug of your dvd player, and keep unplugged for few minuites. and put it back it will eject the cd. or locate pin hole near the " disc tray" (most of dvd player have this hole) insert and push the metal pin( use lengthy pin). best of luck and keep smiling
1 Related Answer
Anonymous
  • Posted on Jan 28, 2009
SOURCE: blinking power light
I got the same problem too.
2answers
Ten pieces of my jwin portable dvd player has a problem with the display it shows white how can i fox that?
White light means that your LCD display panel is not triggering only the back light of the panel is working. They come from China.
Does JWIN DVD players have a universal remote code?
According to jWIN's Support Center, their products do not contain universal codes. Click Here to get direct support from jWIN.
Thank you for using FixYa! Have a great day and please remember to rate this solution.
Best regards,
BearWeb
I have jwin jd-vd503 it does not work it shows
Jwin JD-VD200 / JD-VD203 / JD-VD500 / JD-VD503
  1. (Open the disc tray)
  2. Press SETUP
  3. Press 1, 3, 6, 9
  4. Press LEFT 3 x
  5. Press RIGHT
  6. A new menu entry appears (Version)
  7. Select it and select RC (0=codefree)
1helpful
After disc is loaded, it says "unknown disc."
Is it a pirated dvd? If it is, do you know some dvd players won't read pirated dvds? And if it isn't, then your dvd player may be dirty (the lens). For that you would have to buy a cleaning disk. You can get one at Radioshack. Or maybe what type of dvd type is it? Is it dvd-r, dvd-rw, or what? Some dvd players have trouble reading dvd-rw sometimes.
Hope this helps.
2helpful
I came home one day and nothing worked...the power light just keeps blinking????? what can I do?
Unplug for 24 hours, if still bad then power supply is bad, usually you had a power surge as the unit is still on when it's turned off. Get new unit and buy APC 5 minutes minimum. Ask salesman, he'll help. Way too costly to repair..
4helpful
Code to configure the Universal Remote for my Jwin DVD player (VD141)
jWIN products do not have a series of uniformed universal remote codes, therefore, they can not be provided at this time.
Blinking power light
1helpful
Nesesito un codigo para un dvd marca jwin grasias
Some unlock codes for Jwin DVD players are:
Jwin JD-VD100 / JD-VD703 / JD-VD753
1. Press SETUP
2. Press PREV CHAPTER, NEXT CHAPTER, PREV CHAPTER, NEXT CHAPTER, PREV CHAPTER
3. "VerX" is displayed (X=RC)
4. Select the RC with RIGHT and LEFT (255=Codefree)
5. Press RETURN
Jwin JD-VD120
1. Press SETUP
2. Press 1, 3, 6, 9
3. Current RC should be displayed
4. Select RC with UP, "DOWN" (0=codefree)
5. Press ENTER
Jwin JD-VD130
1. Method 1:Press SETUP
2. Press 1, 3, 6, 9
5. Press ENTER
1. Method 2:Open the disc tray
2. Press PROG
3. Press ENTER 3 x
4. A menu should appear.
5. Select RC with UP, "DOWN" (0=codefree)
6. Press STOP
7. Close the disc tray
Jwin JD-VD135 / JD-VD147
1. Open the disc tray
2. Press SETUP
3. Press 1, 3, 8, 9
4. Use Up/Down keys to change the region
5. Press SETUP
Jwin JD-VD140 / JD-VD501
2. Press 2, 8, 1, 2
3. Use the arrow keys to change the region (9 = multiregion)
4. Press SETUP
5. Close the disc tray
Jwin JD-VD145
2. Press 9, 7, 3, 5
3. Change the region
2. Press SETUP
3. Press 1, 3, 6, 9
4. Press LEFT 3 x
5. Press RIGHT
Jwin JD-VD138 / JD-VD504 / JD-VD602 / JD-VD603 / JD-VD745 / JD-VD903
no known hacks
or you can try here.
Hope this be of initial help/idea. Pls post back how things turned up or should you need additional information.
Good luck and kind regards.
Thank you for using FixYa.
Power Light Stays On
unplug overnight to see if that clears up the problem I this didnt work May have been on the verge of burning out when you unplugged it Maybe a power supply problem
2answers
Power light keeps blinking
Make sure your disk is free from damage or other elements, such as dirt or finger prints. Try a different disk and see if the problem still occurs. You may also be experiencing the problem due to a dirty DVD optical lens. Try using a DVD disk cleaner, available locally, to correct the problem. also, make sure its not a remote control problem; if so, Your battery may be weak and needs replacement...
Top Jwin Televison & Video Experts
ExpressFiX
ExpressFiX
ADMIN Andrew
ADMIN Andrew
Vinho Xie
Vinho Xie
Are you a Jwin Televison and Video Expert? Answer questions, earn points and help others
