Bad inverter, there is a YouTube video on how to fix it if you are interested in doing so.
Dell XPS M1330 LCD CCFL Inverter Replacement How To Tutorial
SOURCE: Unable to adjust the brightness of display screen
bright ness buttons are indicted witha sun like mark . they r usaly used with fn keys look for that keys
SOURCE: Keys dont work.alternative way to change brightness?
Yes you can go into your display properties and look in the settings tab and look for advanced click that and open color tab or the overlay tab, color tab should get your brightness turned up, And if you can't see you can go into your bios and adjust your brightness from there and get it back to where you can see it if you can't write me back here so we can try another method. Ok I hope that helps you out somewhat, Oh yeah you can also hook up an external key board into your usb connections and you should be able to work everything from that too.
SOURCE: led backlight on display for m1330 xps dell
This model laptop uses a CCFL lamp for the backlight, it does not use LEDs for backlighting.
The CCFL lamp is attached to an inverter which supplies high voltage to this lamp.
For details on how to install and or replace CCFL lamps go to
www.lcdparts.net for information and parts.
I assume you are not replacing the whole LCD screen.
SOURCE: Unable to change the Display Brightness
Click Start //Click Control Panel// Performance // screen brightness
SOURCE: My laptop's brightness doesn't work. It's at its lowest.
Ok, I had this problem too. Go into start - all programs - samsung - Easy Display Manager, then start Easy Display Manager. Try your function key and brightness and it should work. If you cant find easy display manage this way, type it into your search and start it this way. I have mine on my shortcut menu and start it every time I re-boot now.
If none of this works, just reinstall the program from here.
http://www.fixya.com/unanswered.aspx?q=samsung+nc10
Hope this helps
Jim
