White (Neutral) White to White Blue (Light to Hot) Blue to Black (optional) Black (Fan to Hot) Black to Black Green (Ground to Ground) Green to Green If you do not have a green lead you might see a green screw to attach the ground wire from the house power. The fan has the optional light fixture future connect the blue wire to the black hot wire. If you have the optional light fixture you may want to connect it to a separate switch power.
SOURCE: where do you connect the blue wire
Next time don't lose the instructions.....
Black is your answer...
If just simply hooking the blue and black together with the black from the switch/power supply does not work you need to replace the wire going to the fan with a 12/3 wire(white,black,red,ground) along with a switch, what you have now is a 12/2(white,black,ground)
Here is the following way it should be hooked up using 12/3 romex to the fan from wall switch.
White,Black, ground power supply
Make sure 12/3 is fed to the fan location.
From the power you Y off the black to the red with a piece of red wire to the switch.
Then from the switch is red wire.
Then at the fan red connects to blue, black connects to black, white to white, and ground to ground.
