2003 Toyota Corolla Logo
Posted on Jan 14, 2011
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
How do I change the license plate light? - 2003 Toyota Corolla
Duane Wong
Level 3:
  • Toyota Master 6,826 Answers
  • Posted on Jan 14, 2011
Duane Wong
Toyota Master
Level 3:
Answers
6826
Questions
6
Helped
2861875
Points
20234
License Plate Lamp Removal & Installation To Remove:
  1. Remove the luggage compartment lock cylinder.
  2. Remove the luggage compartment door garnish molding.
  3. Release the retainers and remove the license plate lamp assembly.
  4. Disconnect the harness electrical connector.
To Install:
  1. Connect the harness electrical connector.
  2. Engage the retainers and install the license plate lamp assembly.
  3. Install the luggage compartment door garnish molding.
  4. Install the luggage compartment lock cylinder.
2002 Cadillac escalade I want to remove the Rear bumper cover to get to the license plate lights assembly to add new ones.
Remove the wheels if possible.
Remove the two clips from each side (by pulling up the center).
Move the fender liner away to access and remove the 7 mm bolt that is near the corner.
Unscrew the four cargo anchors from the floor of the trunk.
Move the trim panel and remove the 4 10mm bolts.
To get to the license plate lights assembly, you can follow these steps:
Open the rear compartment lid and locate the license plate light assembly inside the trunk lid.
Above the license plate, locate four Philips head screws holding the license plate light assembly inside the trunk lid.
Remove the screws (caution: in winter, plastic is extremely fragile and can break easily).
Once the screws are off, your license light assembly is loose inside the trunk lid.
rear bumper cover removal?? ' Cadillac Owners Forum (cadillacforums.com)
2002 escalade changing liscense plate lights ' Cadillac Owners Forum (cadillacforums.com)
License plates bulb replacement
The license plate lamps are designed to illuminate the plate and registration tags on your vehicle and make it easily visible to law enforcement. In many states, a burnt out license plate bulb can get you a ticket.
Step 1: Locate the license plate light. The license plate light is located right above the plate.
Step 2: Determine which bulb has failed. Park your vehicle and set the emergency brake. Turn the ignition to the Accessory position and turn on the driving lights. Walk around the vehicle to determine which license plate bulb has failed.
Step 3: Remove the license plate light cover. Remove the license plate light cover retaining screws using a screwdriver.
  • Note: You may need to use a small screwdriver to pry the cover off.
Step 4: Remove the bulb. Remove the bulb from its retainer.
Part 2 of 2: Install the bulb Materials Needed
  • Protective gloves
  • Replacement license plate light bulb
  • Safety glasses
  • Screwdriver
Step 1: Install the new bulb. Install the new bulb in its retainer and ensure it is in place.
  • Tip: Refer to your car's user manual to determine the correct type of light bulb to get for your specific vehicle.
Step 2: Complete the installation. Put back the license plate light cover and hold it in place.
Install the license plate light cover retaining screws and tighten them using a screwdriver.
Step 3: Check the lights. Turn on your car to check if your license plate lights are fully functional.
2answers
2helpful
HOW TO CHANGE LICENSE PLATE LIGHTS ON 2004 PRIUS
Here is an article on switching over to the LED bulbs, but it shows you what must be done to access the lic plate bulbs as well.
2helpful
How do I change the light bulb above the rear license plate?
YOU HAVE TO OPEN THE TRUNK LID REMOVE THE BLACK PLASTIC COVER FOR THE TRUNK LID LATCH.REMOVE THE LICENSE PLATE LIGHT HOUSING FROM THE TRUNK LID.REMOVE THE BULB SOCKET FROM THE LICENSE PLATE LIGHT HOUSING.TO REMOVE BULB FROM THE SOCKET SIMPLY PULL IT STRAIGHT OUT OF THE SOCKET.
5helpful
How do I change the rear license plate light bulbs?
License Plate Lights Removal & Installation License plate lamp retainer clips
To Remove:
Remove or disconnect the following:
  1. License plate
  2. Pin-type retainers and the luggage compartment lid trim panel
  3. License plate lamp electrical connector
  4. Lamp socket from the license plate lamp
  5. Using a suitable tool, through the access hole, release the clips and remove the license plate lamp
To Install:
  1. Install or connect the following:
  2. License plate lamp
  3. Lamp socket to the license plate lamp
  4. Electrical connector
  5. Luggage compartment lid trim panel
  6. License plate
1helpful
Replace license plate lights.
need to change the incenses plate lights . how do i get to the lights.
6helpful
License plate light replacement
The license plate lights are in the ledge above the license plate. 2 screws keep the lens cover in place. Remove the screws, and the cover comes off. Just pull the lamp out (wedge base) and replace.
I have no tail lights or liscence plate lights
Does the fuse have power in and out when a test light is used? This test would be run with the light switch on.
Top Toyota Experts
ZJ Limited
ZJ Limited
Thomas Perkins
Thomas Perkins
ROBERT GARCIA
ROBERT GARCIA
Are you a Toyota Expert? Answer questions, earn points and help others
