Hello Automatically finds all channels available through antenna or cable inputs, and stores them in memory on the channel list. - Run EZ Scan again after any Antenna/Cable connection changes. 1. Press the MENU button and then use UP/DOWN button to select the SETUP menu. 2. Press the FORWARD => button and then use UP/DOWN button to select EZ Scan. 3. Press the ENTER button to begin the channel search.
To retune your Lg tv, do the following. At first connect the antenna socket at its back side with antenna firmly.
hannel Search
- A password is required to gain access to EZ Scan menu if the Lock System is turned on.
Allow EZ Scan to complete the channel search cycle for ANTENNA, and CABLE
ok.
SOURCE: forgotten reset code.need it to retune
most factory reset codes are 1234 / 0000 / 5555 or 8888
