This most likely means that the over flow tank is full. You can order a replacement tank but you have to disassemble the printer pretty far to get to it. You would also need to reset the counter so ..... if you want you can just reset the counter. Doing this without replacing the Ink Absorber will mean that once it is truly full it will leak into the printer itself. Do so at your own risk, but then again these are cheap printers....
Brother Maintenance Mode Commands:
- Quickly press Menu/Set * 2 8 6 4 to enter maintenance mode.
- Display should read maintenance.
- Press one or more of the maintenance mode commands below. After each
command display should read re-init for a few moments then redisplay
maintenance.
- Press 99 to exit the maintenance mode.
Maintenance mode commands:
01 Full RAM clear (see 91 below for retaining user programming)
02 scanner initialize (feed a white sheet, then a black sheet)
05 white level
09 print test
10 modify soft switches
11 print configuration list
16 panel test
19 CML test
20 signal test
21 tonal test
23 filter RX
54 scan edge
55 scanner area
66 test print memo
75 display drum life (if enabled on laser models)
76 reset drum life counter (laser models)
91 parameter initialize (user programming remains intact)
95 protection
99 Exit maintenance mode"
I would use the 01 and reset everything. Otherwise you can go through the 91 parameter list till you find the counter.
If paper doesn't feed, remove it from the
sheet feeder. Reload it against the right edge, behind the tabs, then
slide the left edge guide against the paper. Make sure the paper is not
in front of the feeder guard.
If multiple pages feed at once, remove the paper from the sheet feeder, fan the edges to separate the sheets, then reload it.
Don't load too
many sheets at once (up to 20 sheets of photo paper, 80 sheets of
Premium Bright White paper, or 100 sheets of plain paper).
You have to know the MODE your camera is in. If you have it in the wrong mode you may not be able to take a photo in some conditions. You typically cannot take a photo of the moon on any auto setting the moon will be a white blob. The moon almost has to be taken manually.
Search for Lens Error. There are many was to fix Lens Errors
displays all white because all the color screen have RGB mode if any of mode's are not work correctlly it's mean's color chip was fail and not working. u have to repair ur camera and change ur display screen.
You have to turn that off , it is called a banner Page, I will sent you a few ways of disabling it. When enabled, the Banner Page prints for each job. The Banner Page consists of the following:
Username
Job Name
Date
Time
From the WorkCentre, enter the Tools mode. See the Related Items below for additional information. The Tools Mode screen will be displayed.
Select [System Settings] from the Touch Screen. The System Settings screen will be displayed.
NOTE: Depending on the model and configuration, there will either be 2 or 3 main screens available in System Settings. For example, the initial screen will be noted as System Settings screen 1 of 2 or 1 of 3.
Select the [Job Sheets] button. The Job Sheets screen will be displayed.
Select the [Banner Sheets] button. The Banner Sheets screen will be displayed.
Select [Enabled] or [Disabled].
Select [Save].
Select [Exit Tools].
Oh yeah
How to enter tools mode would help huh LOL
NOTE: The Tools mode is password protected. The factory set default password is 1111. It is recommended to modify the default password. See the Related Items below for additional information. The Administrator (Tools mode) password used to enter the Tools mode directly at the WorkCentre and the CWIS Administrator password are the same password. If one is modified, it affects the other.
there will be a problem i your sofware for there is some other oprations will be on during when you trying to start camera .
if not
then there is only 1 way awailbe you ask to your phone delaer and update your software
