Saws Logo
Question about Saws
Rip fence is out of alignment..what do I need to do?
Posted by Steve Samsonik on
Anonymous
  • 843 Answers
This is the fundamental problem with rip fences on table saws. I don't know what kind of rip fence you have, but most rip fences are adjustable for squareness. However, unless you have a very nice (and expensive) rip fence, they often don't self-align when you move them anyway. If you have the type that clamps at the front and the back of the table, the problem can be overcome by making sure the rip fence is straight before you clamp it in place. The easiest way I have found to do that is to use an adjustable square. Put the front of the rip fence where you want it, then set the adjustable square so that it matches the distance from the miter slot in the table to the fence. Then move the square to the back of the table and move the back of the fence to meet the end of the square. Now clamp it in place and check the front and the back one more time. It's tedious to do this every time you adjust the fence, but you can get a perfectly aligned fence this way. This method assumes that your blade is parallel to your miter slots, which is adjustable too, but you have to get underneath the saw to do that. good luck, Al K
Posted on Jan 14, 2011
Table saw blade alignment
Are you referring to the table top or rip fence alignment? The blade itself is not aligned. We adjust the table to parallel with blade and the rip fence should toe away from blade 0.01mm over the length of the rip fence to prevent binding.
Jan 14, 2014 • Delta Saws
Sawblade is not parallel with fence on delta tablesaw
The Rip fence SHOULD toe out aprox 0.010mm over the length of the rip fence to prevent binding. Adjust using the Rip fence to measuring rail. Should be adjusters there but if its an old saw, you may have to adjust the measuring rail where it meets the saw frame.
Jan 06, 2014 • Delta Saws
2helpful
How do you adjust the rip fence on the Dewalt 744 type 1 table saw
there are 2 bolts on the backside that you need to loosen and move the fence to the blade to align it properly, after aligning tighten the bolts and I always recheck to ensure that it didn't move, there are instructions in the owners manual and if you don't have one you can go to dewaltservicenet.com and download one for the tool. Let me know if you need more assistance
1helpful
Need a rip fence
Howdy, Here is the ordering page link with the rip fence (called edge guide, part number 2610997206 by Bosch) from Bosch:
https://www.boschtoolsservice.com/Search/QuickPartsOrder.aspx
I would recommend looking in a pawn shop or ebay as the rip fence is nearly 100 dollars as a replacement part.
Hope this helps a bit:)
Regards, Farmerbear
1helpful
Rip fence to saw blade alignment
I dont believe there are pictures, but what you need to do is move the fence to the blade, there are 2 10MM bolts on the backside that you need to loosen and then you can move the fence to square with the blade. Snug them down and move the fence and recheck let me know if you have anymore problems
Problem with 10" craftsman table saw
Your adjustment should be done on the rip fence which will align it to the blade for strait non binding cuts.
After moving the table saw to a new residence i cant get the rip fence to line up with blade.i tried everything that was in the trouble shooting guide.
I am guessing it must be damaged beyond the adjustments. Are you sure the blade is aligned with the table? If not that could be the problem. I have most rip fences for craftsman belt drive saws available, Ebay 'Hokienpokie" or contact me via email, if you need another fence. Jim
Top Saws Experts
Tom Chichester
ray gallant
ADMIN Andrew
ADMIN Andrew
Are you a Saw Expert? Answer questions, earn points and help others
