MY LEXMARK 4505 LEAVES 3-4 BLACK BLOTCHES ON THE EDGE OF EACH PAPER IT PRINTS, TRIED CLEANING THE ROLLERS TO NO AVAIL, ANY SUGESTIONS
ADJUST THE COLOR AND PRINT SPEED
You may need to adjust the color and print speed.
CHECK THE LEVEL OF INK IN THE PRINT CARTRIDGES
1 From the Finder desktop, double-click the Lexmark X5400 Series folder.
2 Double-click the Lexmark X5400 Series Utility icon.
3 From the Maintenance tab, check the ink levels of the cartridges.
If an exclamation point (!) appears on a cartridge, the ink level is low. Install a new cartridge.
Improving print quality
These are possible solutions. Try one or more of the following:
CHECK PAPER
• Use the appropriate paper for the document. If you are printing photos or other high-quality images, for best
results use Lexmark Photo Paper or Lexmark PerfectFinish Photo Paper. Do not use Lexmark Premium Photo
Paper. Your print cartridges are not compatible with this type of paper.
• Use a paper that is a heavier weight or bright white.
CHECK PRINT CARTRIDGES
If the document still does not have the print quality you want, follow these steps:
1 Align the print cartridges. For more information, see "Aligning print cartridges" on page.
If print quality has not improved, continue to step 2.
2 Clean the print cartridge nozzles. For more information, see "Cleaning the print cartridge nozzles" .
If print quality has not improved, continue to step 3.
3 Remove and reinsert the print cartridges. For more information, see "Removing a used print cartridge" on
and "Installing print cartridges" .
If print quality has not improved, continue to step 4.
4 Wipe the print nozzles and contacts. For more information, see "Wiping the print cartridge nozzles and contacts".
If print quality is still not satisfactory, replace the print cartridges. For more information, see "Ordering print
cartridges".
1 Align the print cartridges. For more information, see "Aligning print cartridges" on page 124.
3 Remove and reinsert the print cartridges. For more information, see "Removing a used print cartridge" and "Installing print cartridges"
