Question about Emerson EWF2004 20" TV
My tv is on dtv but can only get channel 2 need help getting the other channels please
Posted by ajones0373 on
Paul Bade
  • Emerson Master
  • 1,688 Answers
I assume you are trying to change channels at the TV, and you don't get a signal on any channel except 2. My guess is you have the DTV converter box connected to the coax (tuner) input on the TV and the converter translates everything to TV channel 2. If this is correct, you select your channels using the converter box instead of the TV.
If this is not a correct interpretation of your situation, please post back with more details.
Posted on Jan 14, 2011
Cannot change channel on my Dynex DX-L26-10a TV
Try checking the signal strength then run the scan again.
Checking the DTV signal strength
You can check the DTV signal strength to determine if you need to adjust your antenna or digital cable input. The higher the signal strength, the less likely you are to experience picture degradation.To check the DTV signal strength:
1.Press MENU. The on-screen menu opens.
2.Press < or > to highlight Channel, then press v. The Channel menu opens. The DTV signal strength is shown at the bottom of the menu.
3.Press EXIT to close the menu.
Oct 26, 2012 | Dell Vostro 200 PC Desktop
I am unable to get any channels on 2 portable tv,s in the bedrooms since the digital switchover are my tv,s now defunct and do i need to buy new ones ??
The 2 portable tvs,dose it have a big bulky back?Yes,than these 2 tvs are analoge tvs.U still can use them though for DTV free air channels broadcasting by running it throught a box called a Ditgital Coverter Box.These Digital Coveter boxes u still can buy them on websites like Amazon.com,Ebay.com to used for analoge tvs wanted to pickup free air DTV channels broadcasting.
Sep 03, 2011 | Toshiba 19AV600U TV
We have an older model tv and can't figure out how to get the channels to above 69
Channels 2 to 69 are over the air - Antenna - channels.
Channels 2 to 125 (some duplication) are Cable channels.
There should be a way to switch your TV to Cable channels.
If it's really old there may be an Antenna/Cable toggle switch on the back of the TV.
Most newer TV's have a way to get a Menu that you can use to switch between Antenna and Cable. Check on your remote control.
If neither of those you'll probably need to buy a new TV.
Jul 20, 2010 | General Electric JASAV22730 Freeview DTV...
I have a samsung p2370 monitor tv.the problem is that the tv channels are kepp coming and go.it says on screen...bad signal.now why is doing that in all channels except 2?I have to say that those 2 are...
Ur tv hookup for free air DTV?Get a better antena like a digital antena,rescan all free air DTV channels, will come back and stable broadcasting signal comming in.
Jun 22, 2010 | Samsung P2370HD 23 in. TV
I recently bought Technika LCD26-209V,I installed
I have a technika lcd26-209v. I want to fit 2 external speakers. Can I just plug them into the TV or do I need to get an amplifier. I just want to broadcast the sound from the tv not play discs etc
May 11, 2010 | Televison & Video
SAMASUNG 32 INCH TV FROZEN ON DTV CHANNEL 1 CHANNEL WORK WHEN YOU CHANGE TO TV CHANNELS 1 - 5 BUT DOES NOT WORK ON DTV CANT CHANGE JUST FROZEN ON CHANNEL 1
These are the steps to reset the DTV features and unfreeze your TV:
  1. Ensure the tv is in analogue mode, not dtv and turn it off.
  2. With the remote: press info, then menu, then mute, then power. These buttons need to be pressed sequentially, not all at the same time, and in quick succession. A menu will appear on the tv.
  3. Navigate to the reset option and press the left arrow key on the remote (or press the enter/ok button). The tv will reset itself and turn off.
  4. Turn the tv back on & it'll re tune all its channels. DTV should be working again.
I hope that helps.
Dec 26, 2009 | Televison & Video
I can't scan DTV channels on my vizio 52''
do you have antenna or cable? if you have antena hook directly to the coax, go to menu, TV, tuner and pick antenna and scan. If you have cable hook directly to your coax repeat the previous step but pick cable instead of antenna. Notice if you have a cable box, you will not need to scan for channel since it will be on channel 3, 4 or any other input you may use.
Jun 20, 2009 | Vizio L32 32 in. LCD HDTV
Emerson EWF2004 20" TV Logo
Top Emerson Televison & Video Experts
Mike
Are you an Emerson Televison and Video Expert? Answer questions, earn points and help others
