You need to replace both door hinges. In order to give more specific directions on how to do this I would need your model number.
Kitchenaid model KGRC707LBSO
Is it an easy job or is it one of those that are a lot more involved then you think?
The door needs to be removed, which depending on the hinge type will have a couple different ways to accomplish that. Some hinges have built in clips to help in removal and others require pins to be inserted into small holes. The new hinges would come with this pins. Once you have the door off its not that difficult to figure out how to disassemble.
This part of my post got cut out. There is a screw on either side of the oven frame attaching the door to the frame. If I remove these screws should the door easily come off?
Is there a parts store affiliated with this web site. If there is I would like to support it, if not I'll order through applianceparts.com.
Once again thanks for all your help Joe
Thanks for everyone's help so far .
Here's a link to the parts list for my ovenhttp://www.appliancepartspros.com/partse...
