Motorola Mobility RAZR V3x Cellular Phone Logo
Posted on Jan 14, 2011
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
Camera not working - Motorola Mobility RAZR V3x Cellular Phone
Anonymous
Level 2:
Sergeant:
  • Expert 194 Answers
  • Posted on Jan 14, 2011
Anonymous
Expert
Level 2:
Sergeant:
Answers
194
Questions
0
Helped
31508
Points
682
PROBLEMS TO SUSPECT.
1.Firmware error
2.Camera dislodged from place due to falls or violent movements.
3.small cord connecting the camera is lose.
4.camera hardware is dead.
SOLUTIONS
1.Update the firmware with the help of a service personnel.
2.If the warranty period is over you can simply open the lop compartment with a precision set and place camera module in correct place. OR contact service personnel.
3.Servicing needed with replacement of cord
4.Replacing the camera unit is the only solution if it goes wrong. http://www.formymobile.co.uk/v3disassembly.php check this link and see how v3s top compartment is disassembled .
plz rate me
Will the Bunker Hill security and the cobra color security cameras work together?
Best Buy says 'No'!
This camera will not work with any other system. The camera and monitor both have antennas that work together, and the cameras are already "paired" to work with the Defender monitor.
Oct 29, 2018
will this camera work with a Bunker Hill Security - Best Buy
https://www.google.com/search?q=Will+the+Bunker+Hill+security+and+the+cobra+color+security+cameras+work+together
1helpful
4answers
In my 4 camera surveillance system two cameras stopped working
The screen should say a message similar to "VIDEO LOSS" if it does The power packs or multi power supply to your cameras are easiest to check for starters. Unplug the power to a working camera and plug it into the non working camera close to the dvr. If the camera that didn't work came on, then the power pack is most likely the problem. If it didn't have a message saying "VIDEO LOSS" then it may be the sensor that switches to day/night vision. I have had cameras that when it switches to night vision the screen goes black and unplugging in the power to the camera and re-plugging it in gives it a boost and then comes on. If switching the power from a working to non working camera don't work get the ladder out and unplug and re plug in the connectors at the camera in case it is a connection there. Last if that didn't work would be to take the camera that don't work off and plug it into the end cables to a working camera, if it works then I would suspect the cable to the camera to be bad. Just a process of elimination.
New cameras work BUT I have no night coverage on the cameras and wonderful day pictures.
You don't want to let more light in the hole if you want it to work at night. Plug one of the cameras that work at night into the plug of one of the cameras that don't work at night and see what happens, if the problem moves with the camera then it is a bad camera or the wrong model for your system.
Lorex video camera not working
First make sure all connections (Both at the cameras and the DVR are connected properly, hand tight.
Next I would make sure they system is up and running.
To ,narrow down the problem take 1 of the malfunctioning cameras and hook it up to where a working camera is hooked up (I would strongly recommend putting a label on each Camera (Working and not working)with masking tape and a black marker, same for the cables at the back of your dvr. i;e. Camera 1, Camera 2, Camera 3...ETC) And as for the cameras write known working on a piece of masking tape attached to each and if possible the cable it's hooked up to (just like you did earlier, camera 1 -4)
Now, with everything running, disconnect one of the no working cameras and walk over to one of the working cameras. IF there all the same cameras just unplug at the camera and leave everything esle as is. Now unhook the working camera, set aside, and plug in the non working camera. If this does not fix it, I would look at both working and non working cameras and make sure any switches that may be behind a panel are EXACTLY the same.(dont change the working cameras settings, just non working) If you have to change the non working cameras buttons try it again. Repeat with second non working camera. If the cameras still do not work then they are faulty. If they did work with or without making any changes to the non working camera then your cable ends and/or cable is bad)
IF none of this helps, try going to the back of the DVR and switching 1 known working cameras cable with a non working cameras cable. IF this fixes it then you unit is bad, if not, then camera and/ or cable is bad as discussed earlier. This should narrow down your problem and put you on a path to getting the system working, not that you know for sure where the problem is.
Nothing works
i cant help you if you note decrib exactly the problem...please say me what you have does with the camera..be for ffaulty or you have see that the camera dont works...have you proove if the camera works with a external suplly... look your camera has a 5 volt jack find a external supplies for 5volt plus internal minus external in the plug in jack proove if the camera works...if the camera works with external supply this is a typical fuji defect ..the internal board have burn the alimt....fuse
and the camera dont work with akkus or batteries paolo italy
Will not show picture and camera is working. Is
Not too much info here. Based on your statement, I'm guessing you are trying to connect a digital camera to your monitor to display pictures on it.
1) Does the monitor work fine as a monitor on its own?
2) Make sure you're on the right display/input setting on your monitor.
3) How do you know the camera's TV-out function is working? Have you tried it on other TVs?
Its possible that the camera is not in display mode. Its also possible that the camera's TV-out is not working. Its also possible that something about the output from the camera is not compatible with your monitor. I would try the following:
1) Test the camera on another TV to make sure the TV-out is working.
2) If its working, go to the appropriate input/source setting on your monitor, before connecting the camera. Then connect the camera, when the camera is off. If nothing displays then turn the camera on, and see what happens.
If that doesn't work, it may be possible that your camera displays in a different set of settings (resolution, etc) than your monitor is able to display. Also I would check the manual for your camera to make sure there isn't some way to adjust the settings.
2helpful
2answers
Can't get the flash function to work on the vivicam 8018 camera
There is a switch on the side of the camera that needs to be in down position (scenery) for the camera to flash. Worked for me.
2answers
IPhone camera stopped working
My iPhone camera stopped working.i press the cam widget and the shutter appears closed.
1helpful
Fisher Price Kid Tough Digital Camera - freezes on logo
This is a solution for getting a working camera, not really to get your camera working. I phoned Fisher Price and was told to format the camera. Turn camera off, plug into USB, right click on the camera drive in my computer and choose format. When this didn't work for me, they sent me a mailing label to send the camera back so they could send me a new one. The formatting is worth a try, and at least you get a new camera when it doesn't work.
Top Motorola Mobility Cell Phones Experts
AFIFUL HAQUE MUFTI...
Level 1 Expert
vince
john h
Are you a Motorola Mobility Cell Phone Expert? Answer questions, earn points and help others
