Maytag EPIC MFW9700S Front Load Washer Logo
Posted on Jan 13, 2011
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
MAYTAG FRONT LOADER WASHER WILL NOT COMPLETE A CYCLE AND SAYS F AND 02
Anonymous
Level 3:
President:
  • Master 1,554 Answers
  • Posted on Jan 14, 2011
Anonymous
Master
Level 3:
President:
Answers
1554
Questions
0
Helped
611850
Points
4917
The fault code indicates a draining problem and the display can be cleared by pressing the Pause/Cancel button twice. Either the pump filter is blocked, the drain hose is clogged/kinked, the pressure switch is stuck in the full position, or the pump itself is not working.
Disconnect power and
remove the three screws attaching the lower front access panel to the cabinet then pull the panel down and off the cabinet. You can prop up the bottom front edge of the washer or cushion and lean it against the wall to access and remove the screws more easily.
Once the panel is off, remove the filter by turning the knob counterclockwise. Clean the filter from any debris that prevents water from draining out properly. Let us know if the problem persists and you need further advice.
Dan Woods
Level 2:
  • Expert 103 Answers
Dan Woods
Expert
Level 2:
Answers
103
Questions
Helped
40529
Points
306
F02 is fault code for DRAIN, the pump may be blocked or the drain hose blocked or kinked. Most washers have an access plug behind the lower front panel of the machine which you can open and check for blockage of the pump.
My Maytag FAV6800 washer hungs part way through a cycle the timer on the front display stops at about 23 on the quick wash cycle.
Sounds like a pressure switch/ chamber issue. Check the tube is clear to the drum. (Assuming front loader?)
1helpful
Neptune front loader will not complete cycle, shuts down after about 10 seconds into fill cycle.
you have a bad temperture switch. that switch also contains the water pressure switch. its reading the washer full of water. change that an the problem will go away. you can find the part you need on sears parts direct.
4helpful
My Maytag Neptune front loader always retains water after the rinsing cycle is complete. This has lead to mold in the door gasket and a moldy smell. Is it normal for water to stay in the machine after the...
pump is probably clogged not allowing all water to drain out. Should never see water in the tub at the end of a cycle. About once a month you should run your washer through a cycle with hot water and bleach. Doing that should keep the moldy smell down.
Maytag front loader HE washer.
cheak your tube if there is a nail or an object is stuck in one of the holes
F 02 reading on front loader washer.
I found several helpful sites from owners who had the same problem and they got the issues resolved, will try what they advised and if that don’t work I’ll call a service technician.
Water leaks from the bottem of Maytag Neptune front loader
Your sewer drain may be backing up.
Check the drain during a final spin.
Water stays in drum after cycle is complete and odor
I think from what you have said, that you have a pump problem. The water pump on most washers collect all sorts of bits and pieces including small coins. You may be able to clean out the pump if it is not a sealed unit.
4helpful
2answers
Controls locked on front loader washer. please help
Press far right button ('with a lock picture) for 3 seconds, the lock will come off.
Top Maytag Washing Machines Experts
Ronny Bennett Sr.
Ronny Bennett Sr.
ZJ Limited
ZJ Limited
Are you a Maytag Washing Machine Expert? Answer questions, earn points and help others
