In my micromax Q7 mobile all incoming calls are replied with this number is busy. Neither I locked nor barred the calls, knowingly or unknowingly. Please get a solution.
baring password is impose by network service provider, default barring password is 0000 or 1234 if not so then call to customer care and ask for barring password.
Normally that's the default password or 1234, but if none of them works, probably it means that your number profile hasn't incoming calls barring service active, this is done at the cellular central office switch, if this is the case, you should request to your cell phone provider the activation of incoming calls barring service (technically called BAIC) at your cell number number profile.
Default call barring password is 1234..To change the password go to settings then call barring. Select options then edit password. Enter current password then new password two times to confirm. Make sure to remember the password. To activate call barring dial *33*1234# if your password is 1234, then press send/call. To deactivate dial #33*1234# then press send/call.
Call barring
Call barring (network service) allows you to
restrict the calls that you make and receive with your phone. To change
the settings, you need the barring password from your service provider.
Select Menu > Tools > Settings > Call barring.
Scroll to the desired barring option, and to request the network to
set call restriction on, select Options > Activate. To set the
selected call restriction off, select Cancel. To check whether the
calls are barred, select Check status. To change the barring password,
select Edit barrings passw.. To cancel all active call barrings, select
Cancel all barrings.
So try contacting your Vodaphone customer service and ask for the call barring code, see if it opens up with a code that they give.
