Question about Kalinka Optics Falcon NCS-03 Weapon Sight
The red dot nor the crosshair is not lighting up,the night vision is working but nothing to aim by
Posted by mb77864 on
Richard Morris
    Master:
  • 577 Answers
Replace the LED or bulb in the reticle. This LED or bulb illuminate the military dot and/or cross-hairs to Red. Red on Green. stewbison
Posted on Sep 05, 2011
What are the 3 dots inside a tasco scope for?
Gauging range. If you set your sight for say 200 yards, you can use the dot reticules for 150 or 250 by using those dots aiming higher or lower.
Google
make model instructions
Mar 04, 2018 | Tasco Optics
Bunker hill security color camera model 95914 suppose to have night vision, has the led lights that circle around the lens. Should those lights be red or at least light up for night vision? I can't see...
If the LEDS are truly for night vision only, then they are most likely Infra-Red types, invisible to the human eye, but visible to camera sensor. A way to test if they are IR and working is to point another digital camera directly at the front of the security camera at night.
The cell phone or webcam sensor will see IR LED's as white spots.
As for this model coming with night vision, I don't know.
Dec 01, 2017 | Audio Players & Recorders
TZS-2
The voltage should be good. It is possible the Infra-red emitter tube might be at fault.
The night vision can work under a full moon, so test the vision part to make sure it is working correctly. If you have an infra red/IR remote control for your TB set, you can test the might vision using that remote to see if the night vision is working.
You can use a second working unit to see if the illuminator is actually working. The illumination is not visible light without assistance.
Jan 31, 2012 | Kalinka TZS-2 'Sova-2' Russian Night...
Why in total darkness does the unit just flicker with no picture? with infrared it works fine
these units need a very small amount of light to work at all, They amplify this small amount of light, with no light at all they have nothing to amplify! the infra red is a source of light so it can amplify that, At night they amplify street lighting or moonlight or starlight etc, hope this helps,
Sep 19, 2011 | Yukon 24021 Monocular
My husband has a Paramount moonlight night vision NV 100 that the lumint red light comes on but the night vision stopped working after only a few months it was bought a few years ago he put up and forgot...
Hello. The red light is the IR (infrarad luminator) this inhance the night vision capabilities of the scope, monocular. Do not look directlly into the IR tube, The Paramount Moonlight has gone to the land of the Red Star. The scope contract is up. it junk, to expensive to repair. stewbison
May 26, 2011 | Bushnell MOONLIGHT Night Vision -...
I got a Night Guardian night vision monocular scope. It doesn't work, but you can see the red pale light on its small reticule if switched on. I dont know why it doesnt work anymore, before it is fine....
These NV monoculars and this Guardian is made by ATN. Normally what happen is the image intensifier tube has gone back to Red Star country. In other words, it gone! The reason why the IR light up is it on a different circuit and has nothing to do with the internal electronic of this NV monocular.
All this IR light does is to provide invisiable light to inhance the image on image tube on very dark/clouded nights. Someone else using and NV devise can see IR light on your monocular and vise versa to you, you can see its IR light. stewbison
May 10, 2011 | Optics
My Night Owl Cyclops NOCC3 night vision monocular wont pick up the infra red light properly so I can't view anything at night!!!! I haven't the lens cap off in light only when it's dark out and it won't...
Hello, is the IR glowing red, don't look into the IR lens. Just place your hand in front of it and see the is a red glare on your had. If there is a red glare then IR is work.
Another thing when you taking a look see through the Night owl NV monocular there should be a green glow from the image intensifier tube, if not, then the NV monucular isn't working properly. stewbison
Feb 21, 2011 | Night Owl Optics Cyclops Compact NOCC3...
I put in a brand new battery in my night owl optics night vision monocular and the red light comes on but i can not see anything out of it.
Hello, this Night Owl monocular will have two light (LED's), one green for on/off, and other red LED for IR illuminator. So, does the green light come on? Also, if still does work, then send it to me. I some parts to fix other NV devise and 95% of them are manufactured in Russia including yours.
I wish you all the luck. GB...stewbison
Dec 20, 2010 | Night Owl Optics Explorer NOCX3 Monocular
Does nothing just red dot lit
internal power section error try to solve that.try to replace power ic.
Dec 15, 2010 | Tasco NV200 Monocular
Kalinka Optics Falcon NCS-03 Weapon Sight Logo
274 people viewed this question
Top Kalinka Optics Optics Experts
Marvin
Marvin
ray gallant
Andrew Taylor
Andrew Taylor
Are you a Kalinka Optics Optic Expert? Answer questions, earn points and help others
