Question about Price Pfister 532-7PCC Marielle Pull-Out Kitchen Faucet with Matching Soap...
The single valve that mounts to the sink is loose. I looked under the sink and see a plate and where the hoses connect to the valve but nothing to tighten the plate. I also took the handle off the top but still not sure how to tighten down the unit to the sink. Thanks for your time. Sincerely D. Price.
Posted by windel2 on
Steve Pack
  • Price Pfister Master
  • 4,342 Answers
There should be a nut hatched to faucet. If not there look in cabinet.
Posted on Jan 13, 2018
5 Related Answers
Anonymous
  • 33 Answers
SOURCE: delta faucet is loose ;moves right-left/wobbles. Tightening?
Try tightening the allen set screw behind the spout "you need a special (allen keys) to do this, and one should have came with your faucet". You can also buy or borrow an set of them.
http://www.efaucetscomplete.com/SpecSheets/T2755CBLHP_Install.pdf
Copy and paste this to your address bar for directions.
Posted on Jan 31, 2009
jgwhomeequip
Jeremy Reddick
  • 1902 Answers
SOURCE: price pfister faucet handle drops and turns off.
There is a price pfister little emblem under neath the handle. Use a but knife and pop that off. Once that is off there is a allen bolt in there. Tighten it up, put the emblem back and away you go
Posted on Feb 14, 2009
Anonymous
  • 3 Answers
Re the 'falling handle' issue, I think you misunderstood the problem, jgwhomeequip. Unfortunately for me I bought *two* similar Price Pfister faucets and both had the same problem - the water wouldn't stay on and the handle just wouldn't stay up.
I took mine apart looking for something to adjust, fruitlessly. Put it back together and have lived with it like that for ~2 years.
Finally I decided to not be a knucklehead any longer and call the manufacturer. Once I got through to their rep (on a Saturday no less!) she helped me identify the model I had (a 533-50SS, just FYI), and asked me 'what finish'? I replied 'stainless steel' and she promptly replied, 'I'm going to mail you out new lighter handles to replace the ones you have'.
Brilliant! Gold star for PP for standing behind their product well past the warranty for what was apparently a common problem. Replacing the handle will take about 10 seconds per faucet.
I only wish I had got of my a$$ and called them 2 years ago.
1-800-PFAUCET (1-800-732-8238)
Consumer Service Department:
7:30am to 4:00pm PST, Mon-Sat
Fax: 1-800-713-7080
Hope that's helpful to somebody.
Posted on Apr 04, 2009
clay
  • 74 Answers
SOURCE: price phister marielle kitchen faucet is leaking
Take the faucet back to where it was purchased as I believe PF has a lifetime warranty on their products.
Posted on May 03, 2009
Anonymous
  • 43 Answers
SOURCE: 533-50 kitchen faucet leaks above base mount at
There are O rings that seal the various body parts of this faucet. I would try turning off the supply lines, removing the handle, and unscrewing the faucet and the housings. Look for O rings that seal each part. Could be a broken, or maybe some foreign material has gotten in the O ring grooves. Best bet would be to replace any O rings and tighten it all back securely. It should not have any Up and Down play, should only swivel side to side. I'm thinking O rings. While there, you can replace the seat seals and springs, so that you preclude any leaks from the faucet itself. Lowes, Home Depot, carry the repair kits for these faucets at a reasonable price. And they usually include the allen wrench and wrench to remove the handle and the body parts. And they are relatively inexpensive. Around 4 to 6 dollars. Its an easy fix.
Posted on Sep 27, 2009
My fawcet hasloosened up from the counter
Take everything out of the cabinets under the sink. Lay down some towels or a pillow, Get a flashlight and look up under the sink. You should see one of two retaining fasteners that are really big nut type fixtures on the bottom of the valves. They are above where the hose connects. Tighten those.
Jun 13, 2015 | Plumbing
Water backs up from the drain in my dishwasher and smells. what is the problem?
Two things can cause this problem:
1. The check valve in your dishwasher may be defective, allowing water and food debris to seep (or run) back into your dishwasher.
2. Your drain hose may not be "mounted up" the way it should be. Look under your sink. Look at how your drain hose is connected to your garbage disposal. If the hose runs down to the floor of your cabinet and into your dishwasher, that is wrong. Instead, it should be mounted up so that water from the sink and garbage disposal would have to flow up first to get into the dishwasher. If you do this, then even if you have a bad check-valve in the dishwasher, it will prevent the problem (or greatly reduce the problem) of dirty water flowing back into your dishwasher.
If you need further help, reach me via phone at https://www.6ya.com/expert/ronald_e6b9572cebe3ad27
May 17, 2015 | Kenmore Elite Stainless Steel 24" BuiltIn...
If the garbage disposal backs up the dishwasher fills with water
Plumbing codes vary in different locations. Some require the dishwasher hose to be connected to an air gap vacuum breaker mounted above the flood level rim of the sink. At the very least the hose should be run up as high as possible under the sink before connecting to the garbage disposer. To keep waste water from backing up into dishwasher.
Hope this helps.
Jan 14, 2014 | Dishwashers
I have never done it before, so I need step by step directions in removing an old blanco single handle faucet and now putting in the new one
Turn your water supply off to the existing faucet.
With a crescent wrench and plyers remove the supply tubes from the shut off valves.
Unthread the sprayer hose that is attached to the brass connector under neath your faucet in the cabinet.
Unthread the lock nut and fastening plate which is on the same brass fitting as your spray hose.
Remove faucet from the sink.
Reinstall the new faucet in the reverse order.
Feb 25, 2010 | Blanco Classic Single Handle Faucet with...
Why water not draining?
sometimes its not the filter. look for the drain hose that connects to the drain pipe (normally under your sink inside your cupboards).
Disconnect the drain hose and look inside where it connects to, most of the tim it blocks up in this area.
Sep 11, 2009 | Hotpoint Dishwashers
Delta 473 faucet very loose where it meets the granite
This is a view from the underside of our sink. Is this what you were talking about? The steel plate is W-shaped (upside down in this case) and has a single nut larger than 3/4". It's almost impossible to fit a wrench up there to tighten it.
Jul 30, 2009 | Delta Model 473: Saxony Kitchen...
Just had bosch dishwasher installed by plumber but it is still not filling up with water. it works after we poor a pot of water in it.
Locate the hot water supply hose under the sink that connects and follow it over to where it will connect to the back of the dishwasher. Look for sharp bends in the hose. There should be a valve where the hose connects to the under-sink plumbing. Rotate that valve counter-clockwise to assure that it is open.
If the problem continues, the solenoid valve may have immediately failed. That valve is just behind where the hose connects to the dishwasher.
Good Luck!
May 08, 2009 | Dishwashers
Grohe 32 071 K4 spewing water from single vale or tube under sink
There should be an o-ring on the mating surfaces of the hose and the faucet that my be missing.  It could also me that the big washer in side of the faucet (under the cartridge) has been shifted.
I doubt it is the cartridge itself, always try the cheap ideas first.
Mar 28, 2009 | Grohe 32.071.KD0 K4 Main Sink Dual-Spray...
Kitchen faucet Installation
Many new faucets require some assembly before mounting to the sink; if that is the case, follow the manufacturer's directions. With most pullout sprayer faucets, the sprayer needs to be threaded through the faucet body first. Insert the rubber gasket between the base plate of the faucet and the sink top to create a watertight seal. If no gasket is provided, pack the cavity of the faucet with plumber's putty, then insert the faucet body through the holes in the sink top. Thread the mounting nuts provided onto the faucet shafts, then center the threaded shafts in the sink's holes and tighten the nuts firmly. Many manufacturers include a special long socket specifically to aid in tightening the mounting nuts. A hole in the socket accepts the shank of a screwdriver, guiding it as you tighten the nuts. If you're mounting the faucet on an installed sink, use this method. If you're installing a pullout sprayer faucet--or a faucet with a separate sprayer--now is the time to connect the sprayer to the faucet body. Check the manufacturer's directions to see if using pipe-wrap tape for this connection is recommended. Use an adjustable wrench to tighten the connection. Most pullout sprayer faucets and faucets with separate sprayers come with a counterweight that attaches to the sprayer hose. This weight helps retract the hose back in to the sink cabinet after you've used the sprayer. Follow the manufacturer's directions on where to secure the weight, and take care not to crimp the hose as you attach the weight. Hook up the faucet's hot and cold supply lines to the water supply shutoff valves under the sink. If necessary, gently bend the copper tubes coming out of the faucet for better access and connect flexible supply tubes to them. Simply wrap a couple of turns of pipe-wrap tape around the threaded nipples on the valves and connect the tubes. Tighten the nuts with an adjustable wrench.
Aug 27, 2008 | Danze D316440RBT Fairmont Two Handle Wall...
Price Pfister 532-7PCC Marielle Pull-Out Kitchen Faucet with Matching Soap... Logo
Top Price Pfister Plumbing Experts
john h
Mike
Michael Thomas
Michael Thomas
Are you a Price Pfister Plumbing Expert? Answer questions, earn points and help others
