SOURCE: Canister motor not on - power to power mate is on
if its a long plastic tube with snaps on it that is where the fuse is.open it up and you will find the fuse
SOURCE: we have a Kenmore canister vacuum cleaner. the
Your hose could be bad. The wires frequently go bad up by the handle switch. also could possibly be the wand, those go bad. You can check that by attaching your powermate directly to the nozzle without the wand and see if the same problem is there. Do you have the mini powermate also? the one that is usually mounted on the wand. If so plug that in directly to the hose and see if you have the same problem. If that tool works fine then the problem is in the powerhead.
SOURCE: I have a Kenmore canister vacuum cleaner. The
check the reset button or the wire that goes into the powermate sometimes it frays and breaks
SOURCE: Kenmore canister vacuum cleaner won't start
The rigidity of the Power Head/Handle is quite durable, :) but sometimes they give out. Have SEARS ...loL, sears, have Sears have a look at the head. :)
SOURCE: I have a miracle mate platinum vacuum. How do I
You can always call the toll free number on their paper bags and ask for a service tech. They have walked me though a motor replacement after my kids sucked up water.
