Question about LG Refrigerators
LG ELECTROCOOL FRIDGE NOT GETTING COLD ...FREEZER AT THE BOTTOM AND FRIDGE. CLEANED THE FINS BELOW BUT CAN'T GET FULL ACCESS TO THE MOTOR ETC TO CLEAN PROPERLY...ANY IDEAS PLZ?? only info i have is as follows: Serial no : 506KRDJ00498 Other no's: GR- 409GQ 56RE7060
Posted by scott_peterj on
Menandro de Leon
  • 1,138 Answers
Hi! and welcome to Fixya.
Posted on Jan 13, 2011
LG bottom two door freezer,heavy build-up of ice at rear of freezer component would like to know best way to defrost fridge
First remove the items from the freeze and place them in a cold box with insulation. Items should last for a day in the cooler. Try to move the freezer away from any wall. Unplug from power source. (place rags/towels/ etc. around the freezer.) If you have a room heater, let it face the freezer from a about 4-5 feet. Allow the area to drip onto towels (replace from time to time) and when it is dry to the touch, clean up the area, including inside the freezer and reset to the normal place etc. Turn the freezer on and let it get cold before you replace the frozen goods.
Jan 11, 2018 | LG Refrigerators
GE profile bottom freezer model # PGSS5NFXA SS. Got up this morning and freezer thawing. Pulled back panel cleaned the condenser fins with compressed air andchecked the connections. runs fine but can'
I had this happen with my fridge when the door was open for awhile when I was cleaning the inside. I did what you did, clean everything behind it. Pay particular attention to the circuit boards, there may be reset buttons in that area. Then unplug the freezer for 10 minutes (make sure it's for a FULL 10 minutes) then plug it back in and try it.
Feb 03, 2015 | GE Refrigerators
Ge profile bottom freezer model # PGSS5NFXA SS. Got up this morning and freezer thawing both fridge and freezer same
Not sure if the compressor is running. If not, you'll need a repair man. Since fans are running, most likely the thermistor. Also, if you haven't unplug from the wall, wait 10 seconds then plug back in; this may reset the control board. The link below may help. GE Refrigerator Not Cold Enough
I have LG Electrocool GR-252SQ(Double door).the freezer is very cool but the lower fridge section is not getting cool.Plz guide.
i have same fridge and my problem is that the water from freezer is not going out pf the fridge, instead it comes down to fridge section through condensation
Mar 24, 2013 | Refrigerators
The motor starts, the fan works, no freezing, just slightly cool air coming from freezer compartment, changed relay, problem persists LG electrocool Model GM 3138c
Many times a freezer and/or refrigeratordo not work right because of a dirty condenser coil...there are also many otherthings that can go wrong. If you are hearing a clicking or buzzing thencheck out the last two tips.
If your refrigerator is running but warm, then...
Check out these tips that I wrote about that... it is a great place to starttrouble shooting your unit...and something that you can do rather then callinga repair person to do a simple thing for you...
Refrigerator Condenser Coil Cleaning Refrigerator Repair
Refrigerator Troubleshooting Refrigerator Compressor
Refrigerator Compressor Start Capacitor and Start Relay
Refrigerator or Freezer not Cooling or Getting Cold
heatman101
Mar 30, 2011 | LG Refrigerators
Sub zero 532. freezer works fine --0 degrees. fridge wont get below 50 degrees. cleaned condenser fins- still no decrease in temp
check the fan that runs between the freezer and the fridge --check fan for ice blockage -debris-or damage / clean or clear blockage --if not running test wiring and connections as well as motor /repair or replace //also check fan damper is not frozen or blocked its flap that opens and closes for air to flow //----ur fridge side is cooled from the the freezer side the cold air is blown in from the freezer if fan or damper is not working correctly than fridge is usually warm and freezer is working properly
Jun 28, 2010 | Sub-Zero 690 Side by Side Refrigerator
Top refrigerator warm bottom is ice cold.
An automatic defrost time turns the defrost cycle on and off every 24 hours. If problem continues, problem is most likely defective defrost timer.
Even electronically controlled units often have electro-mechanical timers for defrost cycle.
Jun 15, 2010 | Amana ABB1927DE Bottom Freezer...
I have electrocool LG MOdel# GR-382R ser# 206MR17803. my bottom fridge cooler area is freezing up.
I have the same problem.It seems that the gasket around the freezer door and fridge door are no longer tightly adhering to the fridge therefore allowing the cool air from the freezer to continiuously entering the fridge storage and making evreything freeze up. I am trying to find out if I can purchase new gaskets and install them myself.
Any recommendation on where to find these and how to install them?
Thanks.
Jun 22, 2009 | LG Refrigerators
My fridge won't cool down or freeze
Your condenser is likely dirty clean it. the compressor could be tripped out on over load (to hot) unplug the fridge a couple hours should do it . plug it back in make sure the thermostat is on and set correctly if that does not work you will need service. Tom
Jun 17, 2009 | LG LFD25860
Refrigerators Logo
860 people viewed this question
Top LG Refrigerators Experts
John Tripp
John Tripp
Colin Stickland
Colin Stickland
Are you a LG Refrigerator Expert? Answer questions, earn points and help others
