Question about Cameras
I am trying to to charge panasonic lumix dmc-zs5 camera battery with it. As soon as I plugged it in showed a red light (power) on the charger. Even after inserted the camera battery the the red light on the power remained but there was no light or indicator for charging. After an hour when I used it in my camera it still was not charged. I could not find any user manual on the net so don't really know how to charge my camera battery.
Posted by runki_basu on
Ty Price
    Brigadier General:
  • 11,967 Answers
User manuals can be downloaded from the support section of the Panasonic website.
Posted on Jan 13, 2011
Panasonic TZ8 showing no charge
It can be the problem with your camera IC.
try servicing it at an authorised panasonic showroom as you can avail warranty if you are on the warranty period.
Jun 10, 2012 | Panasonic Lumix DMC-ZS5 / DMC-TZ8 Digital...
Where do I load 2 batteries in the digipower rapid charger
Panasonic DMW-BCG10, DMW-BCG10E, DMW-BCG10PP Battery, Technical Specification: Battery Type: Li-ion, Voltage: 3.60V, Capacity: 895mAh. Dimension: 41.60 x 30.40 x 9.40 mm, Product Type: Replacement Battery (Brand New). Compatible with: Panasonic Lumix DMC-TZ10 Series, Panasonic Lumix DMC-TZ18 Series, Panasonic Lumix DMC-TZ20 Series, Panasonic Lumix DMC-ZR1 Series, Panasonic Lumix DMC-ZR3 Series, Panasonic Lumix DMC-ZS1 Series , Panasonic Lumix DMC-ZS10 Series, Panasonic Lumix DMC-ZS3 Series, Panasonic Lumix DMC-ZS8 Series, Panasonic Lumix DMC-ZX1 Series, Panasonic Lumix DMC-ZX3 Series. Panasonic Lumix DMC-TZ22, Panasonic Lumix DMC-TZ6, DMC-TZ8 and Panasonic Lumix DMC-ZS5, DMC-ZS7.
Panasonic DMW-BCG10 Battery
Jun 04, 2012 | Digipower Battery Charger
I am trying to to charge panasonic lumix dmc-zx1 camera battery with it. As soon as I plugged it in showed a red light (power) on the charger. Even after inserted the camera battery the the red light on...
IF YOUR CAMERA USES AA OR AAA BATTERIES...TRY USING REGULAR BATTERIES, YOUR CAMERA BATTERIES MAY BE BAD AND NEED TO BE REPLACED.
HOPE THIS HELPS!
Aug 31, 2011 | Cameras
How do you recharge the battery in a panasonic lumix dmc-zs5 digital camera
You need to remove the battery from the camera and use the battery charger for that battery...
Here is the charger
heatman101
Jul 02, 2011 | Panasonic Lumix DMC-ZS5 / DMC-TZ8 Digital...
My DMC-TZ3 battery charger green light is flashing, why ?.
I have the same problem. When I try to charge a battery the green LED onthe charger flashes green and the battery does not charge. Any ideas?
Jul 08, 2010 | Panasonic Lumix DMC-TZ3 Digital Camera
Lumix dmc-fs5 digital camera not turning on without charger.
Some Panasonic cameras only work with Panasonic batteries...part of Panasonic's plan to dominate the world! Is your replacement battery an off-brand?
Feb 19, 2010 | Panasonic Lumix DMC-FS5 Digital Camera
Cameras Logo
Top Cameras Experts
ADMIN Canada
ADMIN Canada
Harrie
Are you a Camera Expert? Answer questions, earn points and help others
