Question about Panasonic Lumix DMC-FZ20 Digital Camera
What size memory cards work with the Lumix DMCFZ20PP? I tried a 4GB and got a read error.
Posted by burntmoon on
DMS-UK
    Scholar:
    New Friend:
  • 81 Answers
Hi
According to the information I have the maximum card size for the DMC-FZ20 is 1Gb SD.
Hope this helps
Dave
Posted on Jan 13, 2011
Testimonial: "Thanks for the info; it answers my Q."
Anonymous
    New Friend:
Hi!
Im using Kingston 2 GB memories. Fo what i know, you can use only old SD cards (Class 2).
Posted on Oct 26, 2011
SD card won't stay in the slot of my Panasonic Lumix DMC-SL80
is the lock on the card by chance. also depending on how old the camera is and how big the sd card is in gb. the lumix may not be able to handle that size of card, too many gb. My lumix would only accept up to 4 gb, so when I moved to 16 they did not work.
Oct 04, 2017 | Nikon Coolpix S210 Digital Camera
Hi. I have a 16GB memory card. I checked it several times with h2testw software and it's working fine. After I shoot about 4GB I start getting "unidentified image" when I try to see the...
The canon PowerShot SX210 IS only supports memory cards up to 4GB in size. Larger ones will work, but because of the format type the camera uses, it won't be able to read correctly past 4 GB.
May 05, 2011 | Canon PowerShot SX210 IS Digital Camera
My Lumix DMC FZ30 use to work using a 4gb SDHC SanDisk card, but now says, "Memory card error please check the card". However, the card works fine in any other cameras. A small pocket Fujifilm camera for...
Memory cards have a limited life. If you've been using it a lot and erasing it or formatting it, it probably is just worn out. Take it to a camera shop and try a new card. If that works, go to a discount store and buy a new one. It will cost less than half the price of that of the camera shop.
May 13, 2010 | Panasonic Lumix DMC-FZ30 Digital Camera
MEMORY CARD ERROR
What photo printer are you using?
It might not be able to read the High Capacity Memory Card. Check the user manual it should say what size and type of memory cards it is compatible with.
Aug 04, 2009 | PNY 4GB Secure Digital High Capacity...
Panasonic Lumix will not read memory card.
try formatting your cd card in your Fz. If it keeps telling you memory error, try using it in windows, put data on it, to see wether it can hold them and read them too.
Happeded to me once too, format did the job. Just format it in the camera, not your pc.
Vladimir
Jul 01, 2009 | Panasonic Lumix DMC-FZ50K Digital Camera
Lumix FX10 - 4gb card reports "card error"
I think you need a SDHC 4GB card. SD is only supported to 2G.
Jul 28, 2008 | Panasonic Lumix DMC-FX12 Digital Camera
Message: Memory Card Error - Memory Card Parameter Error on 4gb SDHC card
I have been rummaging around trying to find two solutions: 1) to get my Toshiba Satellite card reader to read SDHC cards and 2) to get my desktop USB ports to read SDHC cards. While MS offers a hotfix for XP, it does not always work because of the different Chip Sets in computers. I have also read where posters say that the SDHC card works in the compter NOW, but NOW will not work in the camera... and the SDHC card NOW works in the camera but will NOT work in the computer.... I found a tekkie article that may help clear the air... SDHC cards are formatted in Fat32x (NOTICE the "x") and SD cards are formatted in Fat32 (no 'x') and these compatibility problems arise when the user unwittingly or unknowingly RE-formats the SDHC card, either when it is put in the computer and won't read or when it is put in the camera and won't read... but just don't bother to mention that THAT is what they did upon inserting the card and only proceeded to complain about an apparent incompatibility. The camera or computer might even mislead you asking if you want to format the card..... but all is not lost. The Panasonic site gives a program AND a pdf instruction book on How To ReFormat an SD or SDHC card specifying the proper Fat32x or Fat32 format. Hope this helps.
Feb 16, 2008 | Panasonic Lumix DMC-FX01 Digital Camera
I recently bought a DMC-TZ3 and have been researching memory cards. Several sites sell cards with the camera and list the card type. I would suggest buying one of these cards. Any cards larger than 2gb must be SDHC type SD cards. There appear to different types of SDHC cards, 1.0, 1.1 and 2.0. Check out Wikipedia.org for a description. 2.0 cards are not compatable for devices developed prior to 2.0 so that may be the reason for the camera problem. So far I haven't seen anything that states what type SDHC card the camera requires. I found a computer memory site that that sells memory that they say will work. There may be others.
http://www.mymemory.co.uk/compatible-memory/Digital_Cameras/Panasonic/Panasonic_Lumix_DMC-TZ3
Dec 13, 2007 | Panasonic Lumix DMC-TZ3 Digital Camera
Panasonic Lumix DMC-FZ20 Digital Camera Logo
Top Panasonic Cameras Experts
ENFORCER
deton8 von Splosion
Are you a Panasonic Camera Expert? Answer questions, earn points and help others
