Logitech Cordless Desktop MX 5500 Revolution Logo
Posted on Jan 13, 2011
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
How to restart my computer after sleep mode - Logitech Cordless Desktop MX 5500 Revolution
Anonymous
Level 2:
Mentor:
An expert who has written 3 tips or uploaded 2 video tips.
  • Expert 163 Answers
  • Posted on Jan 13, 2011
Anonymous
Expert
Level 2:
Mentor:
Answers
163
Questions
0
Helped
31050
Points
493
Your Logitech cordless desktop MX 5500 will have a sleep mode button which when pressed, the system should start sensing the keyboard activity. In case if this is not happening, the hardware is failing to sense the port where Cordless Desktop is attached. Try to check if you have the apt driver installed and if the desktop supports this function from a cordless desktop. Is this product a branded one ? If yes, please check if then its better to consult the manufacturers help line with out trying for more options.
2answers
I have a tajima TFMX-II C1506 and it wont turn on
Please switch to another mode - maybe power save mode before the machine has a chance to reach the point where it goes into sleep mode. Forcing the machine into another mode, should mean that it can't go into sleep mode.
Thank you.
My Toshiba Satellite S75D-A7272 laptop has always had a problem with getting it out of sleep mode. Is there a fix for this?
Sleep or standby mode should allow your computer to conserve energy yet respond quickly to power back on when you need it. Most Toshiba laptops should exit sleep mode if you press a key on the keyboard or use the trackpad mouse. If the lid was closed, opening it should also wake up the computer. If none of these methods work to bring the computer out of sleep mode, you may have a power issue or software glitch. Causes Insufficient power can cause this problem, so try plugging in your Toshiba laptop before attempting to wake it from sleep mode. If this does not immediately fix the issue, your problem is more likely a software issue. If your laptop was shut down incorrectly prior to the sleep mode incident, it may be stuck on a blank screen that makes it appear to be in sleep mode when it actually is trying to start up.
Indications Press the power button for a few seconds to see if your computer will wake up. If it does, the laptop was not truly stuck in sleep mode, but rather went into hibernation mode. If your laptop is truly stuck in sleep mode, you may be able to force a shutdown by holding down the power button, but when you power back up it will move right back into sleep mode. In some cases, the power button may not shut down the computer from this mode at all.
Solution The best way to solve your Toshiba's problem is to completely remove all power from the laptop to ensure a fresh restart. Close the laptop's lid, turn over the unit and remove the battery. Also remove the power adapter cord from both the laptop and the wall socket. Open the laptop lid and press and hold the power button for approximately 20 seconds. This will drain any stored power in the backup battery. Wait a few seconds, then put the battery back in, plug in the laptop and press the power button to turn on the computer. It may start up with an error screen; in this case, select the option to start your computer normally. If the error recurs, start the computer in "Safe Mode" to see if a program running on your computer outside of the basic Windows operating system is causing the problem.
Further Help Sometimes this issue also requires holding down a specific key, such as "F8," when you restart. If the basic power drain and restart process doesn't work, you can use Toshiba's support website to look up further information for your specific model. Just click the "Product support" tab and enter your laptop's model information, then read through the support bulletins listed for your particular Toshiba model. Toshiba also maintains a support hotline at Call us : +1 850-610-1013 https://www.instantprintersupport.com/toshiba-printer-support
2010 Nissan sentra went into sleep mode when it fuel ran out how to restart engine
There is no sleep mode. Are you sure you ran out of gas? Are you sure you put GAS in the tank and not diesel?
1helpful
How to open hp laptop in sleep mode
This is a common problem on HP computers but also has many causes. If your laptop is not coming back on after being put into sleep mode, it could be a software issue among a few other things. If your computer has a hibernation mode I would suggest using it to get around the sleep mode issue. This mode will save everything the way it is and shut down completely. When you restart the computer it will open up just as you left it. Just like sleep mode except with a restart. This does not solve the sleep mode problem but easily provides a power saving alternative to it.
Computer goes into sleep mode, proper way to get out, besides shuting down and restarting
The usual way to get a computer out of sleep mode is to either hit the return key, the space bar or the on/off button.
Sleep mode can be a nuisance at the best of times so i would recommend going into power options and disable sleep mode.
Regards.
3helpful
Lg 2234s monitor will not come out of sleep mode
restart the computer and the monitor. If the monitor is still in sleep mode then hook up the monitor to another computer that is working. If the monitor is still in sleep mode then that means that the monitor is bad.
If the monitor does work on another computer then that means that your computer has no video output and its an issue with the computer, you'll need to try and unseat and reseat the memory to see if that brings back video output to the computer.
2answers
Monitor keep going into "sleep" mode
Check the power setting in control panel of windows. If you have a monitor from another computer swap them and see if the problem stays with the computer or monitor.
Monitor willnot come out of sleep mode
turn off everything and restart computer in safe mode,do this by holding down f8 as you reboot,then go in your setting and remove time limit on sleep mode.
7helpful
Power saving mode knocks the computer out, have to restart
I have an LG Flatron 19" black w1952TQ that I bought on 2 Apr 2008; when it goes into sleep mode, will not recover. Did the online troubleshooting, reseting things, unplugging/replugging all cables, nothing works except restarting the computer, and that only works until it sleeps... Read more
My computer will not go to stand by or sleep mode
Were you able to make the computer go to sleep mode before? Well what you can try doing is go to start, run and type msconfig, click ok. You will get the system configuration window, then go to the startup tab in the system configuration window and at the bottom of the window there is a button as disable all, click that and on the same window there are startup items, select the antivirus program and items that you would need to have at the task bar. Then click apply and ok. You will get a message to restart the computer. Click restart. As it restarts you will get a message saying that you have used the system configuration window, click do not show me the message again in the message. Also you can go to start, right click on My computer and go to properties, click the hardware tab, and select the device manager button. That would show you the device manager window. From the list of hardwares listed in the window, right click on network adaptors, properties and under the power management tab uncheck all the power options checkboxes. Now you can close all the windows and try to go to sleep mode again. You can also try disconnecting the USB devices as you try going to sleep mode and see if that works, if yes, try connecting the USB devices one at a time and check again.
Top Logitech Computers & Internet Experts
ExpressFiX
ExpressFiX
Grand Canyon Tech
Grand Canyon Tech
k24674
Are you a Logitech Computer and Internet Expert? Answer questions, earn points and help others
