Water Heaters Logo
Posted on Jan 13, 2011
It is leaking out of the top. not out of the hot or cold valves but out of a nut by the cold side.
A
Anonymous
Your tank is rusted out and needs to be replaced.
Link below is a troubleshoot for leaking water heater.
http://waterheatertimer.org/Leaking-water-heater.html
Protect yourself first:
If your tank is rusted, there is danger of rupture.
My friend welded his leaking tank, but he assumes the risk.
Ruptured tank can cause massive damage and water runs until it is shut off.
Hot water tank is under pressure because hot water expands and pushes against tank wall.
Turn off water to tank.
Turn off power supply:
Electric: turn off circuit breaker.
Gas: rotate knob to pilot so pilot stays lit but burner will not fire. To turn back on, rotate knob to ON.
Open hot side bathtub valve and relieve pressure on tank.
You can limp by with rusted tank by turning water heater on when hot water is needed.
Shower uses 5-9 gallons hot water
Bath uses 12-15 gallon hot water
Ordinary gas heater makes 41 gallons hot water per hour
Ordinary electric heater makes 20 gallons hot water per hour.
I buy water heaters at Lowes, Home Depot, Ace.
Look for scratch and dent models.
Buy drip pan for water heater.
Wrap electric heater totally with insulation except TP valve.
Buy new flexible connectors for water lines.
Offer 15% less than marked price on tank, because the store makes money on additional items.
> Most people can install their own electric heater since you just connect water pipes and electric wire, and it's done. Read link below since there are tips that help you buy and install electric.
> Generally people are nervous about installing gas water heater, so step-by-step instructions are shown on link below. Remember gas line is under less pressure than water line, so if you can install a water pipe, you can install gas line to water heater with crescent wrench, and soapy water to check for leaks.
How to install gas water heater:
http://waterheatertimer.org/How-to-install-gas-water-heater.html
Add a comment for more free help.
Also take advantage of fixya phone service.
For a price, fixya expert speaks with you over phone while you work on water heater, or any do-it-yourself project.
1helpful
2answers
How and where does the water go in
The cold water enters the top, but the water is not released into tank at the top. The cold water goes through a "dip tube" This takes the cold water to the bottom of the tank. If you dip tube fails, or breaks, your faucet temperature will slowly drop as you use hot water (vs giving you 60% of tank at full temperature before temperature starts dropping) In normal operation, the cold water is released near bottom of tank, the hot water rises to top, and comes out of the top of the tank.
Btw, I’m available to help over the phone in case u need at https://www.6ya.com/expert/perry_14036f9bc71cde6a
2helpful
2answers
Hot water keeps running hot and old
Fastjet,
I can't understand what you are asking...
Please clarify via a comment.
perhaps a leak?
My anode rod, and dip tube and t& P tube relief gasket is leaking
Copy following link for general troubleshoot:
Then add a comment and let's get the problem solved.
FYI:
Anode rod is either connected to hot-water nipple, or installed in separate port located top of tank. Anode stops water heater tank from rusting.
Dip tube is a plastic tube that is connected to cold water nipple and extends to bottom of tank so cold water always enters tank bottom.
TP valve is brass safety valve that is screwed into a port located on top of tank, or located on side of tank, and will release water when pressure or temperature exceed rating of TP.
If you need further help, I’m available over the phone at https://www.6ya.com/expert/gene_9f0ef4df2f9897e7
I have a Rheem 50 gallon electic water heater that seems to be leaking from the on/off lever at the top of tank. Do you have a replacement part for the on/off lever? Thanks, Cindy
If you are talking about the water valve on the cold water inlet it should have a nut under the lever if it is a quarter turn ball valve.If so you can remove the nut that hold the lever on and carefully tighten the nut by turning it clockwise.This should stop it leaking if it is coming from around the stem. If it is a globe type valve there should be a packing nut that goes around the stem under the handle. Tighten this nut carefully to get leak to stop. If it is leaking anywhere else then you will need to have the valve replaced.They are available at almost any hardware store.Thank you.
Water seems to be leaking from the top lid of my ge water heater
Make sure any water valves (Cold or Hot) for water heater are not leaking first. Gate valves may leak at the packing nut over time and drip on top of tank. If water is leaking from the top of the water heater itself the tank is corroded and water heater will need to be replaced.
RJ
Turned off the hot water to fix a leaking tap. now the tap has no hot or cold water and the hot water tank valve is leaking?
It sounds like two problems.
Problem 1) Clog inside faucet or clog inside pipes at faucet
Remove supply tubes leading to faucet and see if problem is inside pipes or inside faucet.
My bet is clog inside faucet.
If you have galvanized pipe that meets copper pipe, this can be trouble spot.
Article on clogged water pipes at Inspectapedia:
http://www.inspectapedia.com/water/Water_Pipe_Clog_Repair_Guide.htm
Article on clogged pipes:
http://www.waterheaterrescue.com/pages/WHRpages/English/Troubleshooting/Tanklets/backflushing.html
Problem 2) Water heater leak ... you say tank valve is leaking? Is that cold-water shut-off valve? Or tank drain valve? Or TP valve?
If cold water shut-off is leaking, then replace shut off.
If tank drain valve is leaking, then check if plastic valve is cracked. If drain valve is cracked, then replace with a brass valve from Home Depot. If plastic valve breaks off, then use hammer and screwdriver to gently chip out the broken plastic valve. New valve threads need teflon tape to seal pipe. If valve is just dripping, then put garden-hose cap over end of valve and screw down tight.
If TP valve is leaking, then replace with same temperature and pressure rating.
New TP valve threads need teflon tape to seal pipe.
Problem 3) If pressure is low all over house:
Buy pressure gauge at hardware store that screws onto hose connection.
Test pressure on outdoor spigot.
Open faucet and check if pressure drops. This says if problem is inside pipes that enter house.
Test pressure on water heater drain valve.
This says if pressure problem is before -or- after water heater.
If problem is before the water heater, then shut-off valve located on cold water line is suspect.
If problem is after water heater, it could be in hot water outflow pipe on top of water heater, or a nearby elbow.
Remove hot water line leading from water heater and check pressure. This says if problem is where hot water leaves tank.
Read articles above about clogs inside water lines.
We have a reliance 606 50 gallon electric water heater. recently we noticed it has an internal leak. I removed the top and removed some of the insulation. the pipe fittings are dry but when you put water...
I wrote a page on leaking water heaters.
With a checklist.
It sounds like you've done quite a bit already.
The element can leak around the gasket.
The TP valve can leak where it screws into side of tank.
Otherwise a leak on side of tank sounds like the tank is rusted through and needs to be replaced.
http://waterheatertimer.org/Water-heater-leaking.html
You should turn off electricity and water to the tank, and open tub valve on hot side to relieve pressure so the tank will not rupture.
Then you can limp along with a failed water heater by turning the water and electricity on only when hot water is needed.
This will buy you time until a new heater is installed.
A typical electric water heater produces 21 gallons of hot water per hour.
A shower uses 6-9 gallon of hot water, so heater only needs to be turned on 20-30 minutes for a shower, more if the incoming water is very cold.
To economize with your next heater, you might read the following two pages:
http://waterheatertimer.org/9-ways-to-save-with-water-heater.html
http://waterheatertimer.org/Replace-anode-rod.html
My suburan hot water in my 5th wheel camper only makes warm water, never hot. what is the problem?
First, let water heater heat up until it shuts itself off. Now carefully, ( it should be hot) open pressure relief valve slightly and catch some hot water in a cup or container. Compare it to what comes out your tap, that you say is warm only. If that water from pressure relief feels hotter, then check your by-pass valves for proper operation and position on rear of water heater, as it may be in a position that is allowing cold to mix with hot, creating warm. Cold line will go direct in the bottom fitting and hot will come out top fitting, and make sure any valves in between those 2 lines are in off position. If all is well there, or water from pressure relief is only warm as tap as well, then buy a new thermostat and ECO for that particular model water heater from RV dealer/service center, and replace them. They are behind rubber cover on upper left side on water heater. When cover is off, they are held against tank by 3/8 nut. When you replace it, snug nut up good but be careful not to go too much and snap that small brass stud that nut goes on. Pay attention to position of old one, so new one goes same way.
Water leaking from the bottom of the big PVC pipe parallel to the water heater
What is the leaking pvc pipe connected to? The T & P valve on the side (or top) of the tank? Or is it an incoming cold or outgoing hot water line? If you have just lit the water heater, the T & P valve may drip, but only for a little while and it will stop. The T & P (temperature and pressure relief) valve may be bad and need replaced. Turn off the incoming cold water valve and turn the gas valve to off position. Then drain the water heater using the T & P valve, it will stop draining when the water level is just below it. Remove the T&P valve and replace with new one. Use thread sealing tape on threads. Or call a plumber if not sure.
1helpful
2answers
No water pressure in bath tub after turning off hot water heater
It could be back flowing into the hot water heater tank which is not full because of the leak. Even though the valve is closed on the cold water entry side, there is probably no valve on the exit side. That is how it is returning to the tank.
Top Water Heaters Experts
Paul Carew
ADMIN Andrew
ADMIN Andrew
Are you a Water Heater Expert? Answer questions, earn points and help others
