Question about Jabra BT530 Bt HDst Black Bluetooth Headset
Why can't i get my jabra to paired with my c 3 phone
Posted by sandicyrus on
Anonymous
    Director Badge:
    Uploaded 100 video answers.
  • 1,751 Answers
Hi
you need to check the batteries
if are ok
open it and search from your phone for it
Posted on Jan 13, 2011
My phone asks for headset in "discoverable mode" How do I get it there?
What kind of phone do you have? I have heard people with LG phones say that it does not pair with their phone. If this is not an issue with you then these steps may be more helpful:
1. Charge your Jabra BT135 until the solid blue LED turns off
(approximately 2 hours)
2. Make sure the Jabra BT135 is switched off
3. To put the Jabra BT135 in pairing mode, press and hold the multifunction
button until the LED stops flashing and turns solid blue
4. Set your mobile phone to "discover" the Jabra BT135 (see your phone
user guide)
5. Press Yes or OK when asked if you want to pair the phone with the
Jabra BT135
6. Enter passkey or PIN = 0000 (4 zeros), then press Yes or OK
7. Your phone will confirm when pairing is complete and your headset
will flash
Jun 17, 2011 | Jabra BT135 Bluetooth Headset
I have a samsung phone and i am trying to pair it with my jabra vbt185z but i don't know the passkey...i tried using 0000 but that didn't work. so what else can i do to make it work?
You do need the passcode. It should "auto pair" but the default passkey or pin is 0000 (4 zeros.)
Here is a link to the user manual
http://www.jabra.com/sites/Jabra/GNimages/Products/WirelessHeadset/BT2010/Documents/UM/VBT185z_UM_6198.pdf
Headset Pairing Readiness Instructions:
1. Fully charge headset for two hours.
2. The headset will automatically go into pairing mode if no device has
been previously paired.
3. Set your mobile phone to 'discover Jabra VBT185Z'.
4. Enter passkey or PIN = 0000 (4 zeros), then press Yes or OK.
dw
Dec 31, 2010 | Jabra BT150 Wireless Headset
How do I sink my Jabra BT4051 with my Nokia 2720a . I do not have a manual any more.
Usually the following setup is required to Pair bluetooth headset with mobile phone. Your mobile phone should support bluetooth interface. 1. Put the headset in pairing mode ? Make sure the headset is off. ? Press the on/off/pairing button marked until the LED indicator light is solid blue. 2. Set your Bluetooth phone to ?discover? the Jabra device Follow your phone?s instruction guide. This usually involves going to a ?setup,? ?connect? or ?Bluetooth? menu on your phone and selecting the option to ?discover? or ?add? a Bluetooth device.* 3. Your phone will find the Jabra device' Your phone then asks if you want to pair with it. Accept by pressing ?Yes? or ?OK? on the phone and confirm with the passkey or PIN = 0000 (4 zeros). Your phone will confirm when pairing is complete. In case of unsuccessful pairing, repeat steps 1 to 3.
May 12, 2010 | Jabra BT4051 Bluetooth Headset
How do you put the device into discovery mode
Before you use your Jabra BT160, you need to pair it with your mobile phone. 1. Put the headsetin pairing2 mode Make sure that the headset is on. Press the answer/endbutton and press the volume up (+) button at the same time, until asolid blue light comes on. 2. Set your Bluetooth phoneto ?discover? the Jabra BT160 Follow your phone?s instruction guide.This usually involves going to a ?setup,? ?connect? or ?Bluetooth? menuon your phone and selecting the option to ?discover? or ?add? aBluetooth device 3. Your phone will find the Jabra BT160 Your phonethen asks if you want to pair with it. Accept by pressing ?Yes? or ?OK?on the phone and confirm with the passkey or PIN3 = 0000 (4 zeros).Your phone will confirm when pairing is complete. In case ofunsuccessful pairing, repeat steps 1 to 3.
USER GUIDE
Jan 03, 2010 | Jabra COMMUNICATIONS BT160 Bluetooth...
How do i program my jabra bt125 headset to my cell phone
taken from the manual found at
http://www.jabra.com/sites/Jabra/GNimages/Products/WirelessHeadset/BT125%20Black/Documents/User%20manual/BT125_UM_NA_EN_471.pdf
• Make sure the headset is off .
• Press and hold the answer/end button until a solid blue light comes on.
2. Set your Bluetooth phone to ‘discover’ the Jabra BT125
Follow your phone’s instruction guide. This usually involves going to a ‘setup,’ ‘connect’ or ‘Bluetooth’ menu on your phone and selecting the option to ‘discover’ or ‘add’ a Bluetooth device.* (See example from a typical mobile phone in fig. 3).
3. Your phone will find the Jabra BT125
Your phone then asks if you want to pair with it. Accept by pressing ‘Yes’ or ‘OK’ on the phone and confirm with the passkey or PIN = 0000 (4 zeros). Your phone will confirm when pairing is complete. In case of unsuccessful pairing, repeat steps 1 to 3.
Dec 04, 2009 | Jabra BT125 Headset
I need to reprogram my Jabra BT125 to a new phone, but don't have the instuctions to do that.
7. Pair it with your phone
Before you use your Jabra BT125, you need to pair it with your mobile
phone. (Follow step 1-4 in fig. 3).
Jul 12, 2008 | Cell Phones
Problem pairing
Before you use your Jabra BT130, you need to pair it with your mobile phone.
1. Put the headset in pairing2 mode Make sure that the headset is on. Press the answer/end button and press the volume up (+) button at the same time, until a solid blue light comes on.
2. Set your Bluetooth phone to ‘discover’ the Jabra BT130 Follow your phone’s instruction guide. This usually involves going to a ‘setup,’ ‘connect’ or ‘Bluetooth’ menu on your phone and selecting the option to ‘discover’ or ‘add’ a Bluetooth device.
3. Your phone will find the Jabra BT130 Your phone then asks if you want to pair with it. Accept by pressing ‘Yes’ or ‘OK’ on the phone and confirm with the passkey or PIN3 = 0000 (4 zeros). Your phone will confirm when pairing is complete. In case of unsuccessful pairing, repeat steps 1 to 3.
Jan 27, 2008 | Jabra BT130 Wireless Headset
Pairing problem
Dec 23, 2007 | Radio Communications
Does not link with razor cellphone
Dec 16, 2007 | Jabra BT130 Wireless Headset
Setup
Sep 13, 2007 | Jabra BT130 Wireless Headset
Jabra BT530 Bt HDst Black Bluetooth Headset Logo
Top Jabra Radio Communications Experts
Richard Schabler
aliasger yq
 Mikey
Mikey
Are you a Jabra Radio Communication Expert? Answer questions, earn points and help others
