SOURCE: gforce 6100sm mv 1.0 loading xp64
i think trojan horse is attacked to ur hard drive instal some good antivirus and give for search ..
if problem persists then give full format dnt give quick format ...
if there are many partitions then the only way to get rid of the problem is to delete all partitions & by repartitioning your problem will be solved.....
SOURCE: computer won't run windows and come up with a trap-handler error
on the IDE Port, set the jumpers to the hard drives/cdrom on CS(Cable Select) this lets the BIOS and the ribbon cable decide which is primary (Master) and which is secondary (Slave) on that IDE cable. if they were configured wrong you would get an error.
If the IDE channel is no good, try switching the primary and secondary IDE ribbon cables.
SOURCE: Mercury Mainboard PVCLE266M-L v3 Manual
i have a problem in my pc when i switch on its bring the sound only without showing anything what should i do?
SOURCE: Latest Bios For The E210882
You really should contact Emachine support. I looked for your model # 5250 among all their various model ' series ' with no luck on my end. I also thoroughly investigated the Intel website for your motherboard model # and that doesn't show up either at least not as written by you. I did find on the Japanese Intel website a model that was very similar tho. It is written as D915GAV, not GVA and the website for reference is very hard to read by most West Europeans and Americans. So my strongest recommendation is to go with the first link to Emachine support. I'm sure they can be of some help to you.
try this link.. http://www.userdrivers.com/Motherboard/Intel-D101GGC-Desktop-Board/download/
