My husband bought a canon Pixma 495 allin one and there is an error code flashing and its preventeing us from installing printer software
the error code is P22 and the alarm lite is flashing along with color
To print the LAN settings, press the Maintenance catch on the printer over and over unti you see a n on the LED, then press the Black or Color catch. When it prints out, let us know whether the association is Active or Inactive. On the off chance that it is Active, please let us comprehend what it appears for the IP Address and Default Gateway. If you want to get proper detailed information then 'you should call on 1-888-924-2961 toll free number anytime for canon printer support service. Technical Support For Canon Printer
If you get a warning regarding Ink is Empty and even you cannot Scan your documents then you might require a small R&D, Just hold Stop/Reset button for about 5 seconds, then open cartridge access door, Remove both the Cartridge's and wipe it with the wet tissue or cloth... spray water or deodorant on the exposed golden surface of the cartridge and do not let it dry, install as soon as possible... Then close the cartridge access door and switch off your printer, then Re-start it and connect to your computer, Hold Stop/Reset button for 5 seconds and then enjoy scanning...
Dear maumee, Please be more specific on how many times it flashes. Canon printer has about more than 15 variation of flashing LED. Check here to find out about LED flashing error description. Regards,
What is the brand name and model of your printer? Make sure that your ink cartridges are precisely the correct cartridges for the brand and model that you are using. From what I have experienced ... if you try to use a used ink cartridge you will recieve an error.
I have canon PIXMA ip3000. After power cut at night printer doen not
print. I re installed the drivers but no result. When try to print
message appears printer is offline. POwer button is flashing shorthly
green after orange lights. Error code 5100.
