I responded to the previous question in regards to the motor only. The xp2 does not have the strainer basket that the max-e-pro has . If this was a regular hot tub, the xp2 would work great, if this is above ground, then you do need a pump with a strainer basket. Again the xp2 will not work for an inground hot tub as the set up is different than an above ground unit.
Testimonial: "Thank you so much. That helps alot. Do you have any other suggestions for a pump tha might be less expensive then a Max E Pro?"
