Lionel Cw 80 Transformer Logo
Question about Lionel Cw 80 Transformer
I have a lionel type KW Trainmaster Transformer and the cord to the 110 volt outlet needs to br replaced. How do I remove the terminal cover (there are no screws on the bottom of the transformer to dismantle) and what do I then do? 18 gauge wire and plug?
Posted by gcox112 on
Anonymous
    New Friend:
New wire and plugs are available at chuckstrains.com , they can also tell you how to get into it
Posted on May 10, 2013
  • Traindoc Jun 16, 2014
    There should be some screws on top of the KW that hold the shell on. You'll need to pull off the handles first to lift the shell.
4 Related Answers
Anonymous
SOURCE: I am trying to hook up a Lionel 1033 transformer
I have the original Instructions for Operating the 1033(written in 1953) - the second paragraph of the "How To Connect Transformer" reads as follows: The "Multi -Control" transformers listed in this leaflet have four binding posts located on the top of the transformers. Of these, "A-U" and "B-U" combinations furnish variable voltage for the track. The control arm of the transformer simultaneously regulate the voltage output of both the "A-U" and the "B-U" combinations. The transformer nameplate indicates the voltage ranges of these two combinations.The "A-U" combination supplies any voltage from 5 to 16 volts. The B-U combination has voltage from 0 to 11 volts. In selecting the proper range of voltage for your particular outfit, try the lower "B-U" combination first. If the maximum train speed is not satisfactory, then try the "A-U" posts.
To paraphrase the "How to Connect Accessories" section: accessories work best with fixed voltage - these voltages are obtained from the following pairs of output binding posts: "A-B" 5 volts; "B-C" 11 volts and "A-C" 16 volts.
Hope this helps, Mark
Posted on Dec 06, 2011
Anonymous
SOURCE: My new Lionel CW-80 trans former stopped working
I did the same thing as brian-sw. Opened the unit, removed the old in-line fuse and added an external fuse holder to make it easier to replace in the future. Transformer is difficult to open unless you have the triangular security screw driver. Security bits can be purchase from Harbor Freight but you will need to adapt them to fit into the channels where the screws are recessed. It certaintly would have been nice if Lionel installed an external fuse or circuit breaker. Guess they didn't want to loose the repair business.
Posted on Dec 19, 2008
Anonymous
  • 10 Answers
SOURCE: No longer have manual for
See link below to PDF file with instructions to your transformer. It looks like you are correct with regards to the wiring with what I can see in the manual.
Hope this helps and good luck
www.lionellines.com/files/manuals/KW_Manual.pdf
Posted on Aug 04, 2011
Anonymous
  • 10319 Answers
SOURCE: how do I replace the
These transformers are fusioned together which takes a skilled hand with a hot blade to separate the bottom from the top shell. Hot blades are commonly used by glass repair techs that replace windsheild on vehicles
Posted on Aug 26, 2011
My iPad 6 won't charge properly in countries with 110 volts but works where it is 240 (where it was originally from...I have bought new cords etc but only charges properly overnight or in the car.
You need a 110v to 240 volt converter
google search
110V to 240V Step Down Up Transformer Voltage Electricity Converter Adapter
or
go to a local apple store and purchase a 110v 12W USB power adapter designed for IPAD 6
DON"T PLUG a 110V usb power adapter into 240V as smoke will come out of it and it will stop working
2answers
I'm overseas Plugged 110v KA mixer into 220v outlet by mistake, and it wouldn't start up anymore. Can anyone please help me identify which parts need replacing + good online vendor Thank you
You need a "step Down Transformer" Available on ebay for about $10-$11 see this link https://www.ebay.com/itm/1600W-WATT-220-TO-110-VOLT-TRAVEL-POWER-VOLTAGE-CONVERTER-TRANSFORMER-STEP-DOWN/261271470822?epid=2280961078&_trkparms=ispr%3D1&hash=item3cd4fe42e6:g:uyYAAOSwWV9bPnrq&enc=AQADAAAB8KX%2FKt4E1xf3SDqEdBclaYb3BEV2goiLGFm8pFHXtqqWxpi8UuZ%2B1UmMICagX0mPwzYtCPZLcL0E6Vaah6ZHw722DadNzkh3SM4MH25CRSPyDz9KvizBus75NMrUzhlRLp%2B4V42jC8hHgHYIYx%2B%2F4ycoFIijohPaTQWlPWqQoiUUUNXGfcFmCpcoSSrOtf3PVZcoJ9puUxTsrWPljut5U1XkLTUpfC8GRbje9eRdiyaqM1czASyOWZZgzA57iczV5z3vANeoEC%2BNacVC7bZrYUq5aG3%2F%2FawiBxNf8TwriwXCOw4nCe1FY2tLmRo1wBhjzLcjKTSoA9NXOgfP9yx2GAHB0aImAG6lwuD1Gjsbujapr0tOx303NO4%2FGDIjh23zBM2fFEjQ2lGE4u18hjWq90SC6CeIR6MRzjQmQFq0b%2BCQhZ966xg8sO6%2FP5M15emZQZPI4Wuwx6hC%2FWdQTFVmAkRx5XK1ZrG1qEUEGpPaD1FfdbI0tdiajTnoGtyj%2BYHYMLv7LJIQy8LPkNOtVsM4s4wNyFX29hZBcd90%2BBD9nVBT5XxRvvRld9N6uirS7H1399hftHO5SQD%2F44k8oA6tIY8fkYHruTeGLpXXjdFSuaWZZIJ0ehjAYwCMW6mHoymA2EJQOmGfV1RnrN%2BpaghdG54%3D&checksum=26127147082247fa4391f0f146d69550a6c6cdd31f82
https://www.6ya.com/callphilipforhelp
Want to use this on 220v aussie supply to power 1947 221 lionel train loco Suitable?
ohh no that id not try at all , one can first use a power converter that one can buy off many online sources to convert 220 volt down to 110 volt then to transformer this will be safe 4 unit, the 50HZ to 60 Hz doesn't matter to much as well unless one plans on using the lionel sound generator , then its not gonna sound to spry as it will be a bit slower !!
1helpful
2answers
What do i have to do to plug my 110 air conditioner into where my 220 window unit
You need a step down transformer, to convert 220V to 110V. You can't just plug the 110V A/C unit in directly unless it is clearly marked as being suitable for multi-voltage supply (110V - 220V input).
Such a transformer has to be of sufficient capacity to handle the current, or wattage, that will be required. The Frigidaire unit in your question is a 3.5 kW cooling capacity, so the transformer would need to be about the same, ie for a 10A supply at least. They are quite big boxes, about $120.
http://welectronics.com/TRANSFORMERS/step-up-down.JPG
You would put this in the roof or in a cupboard.
Can two tracks be powered with the Lionel Trainmaster R 100 Watt transformer?
Track 1 as you have it connected is terminals B-F. The second track would be terminals B-C. Connect post B to the outer rails Terminal 1 ? on your lockon. THis will give you 6-16 volts at the track.
Dec 01, 2013 • Toys
2answers
How can i convert our 220 volts wall outlet to 110 volts for a microwave oven.
Find the breaker for it (a double for 220) and substitue a single breaker (for 110). This will leave one wire unused from the breaker box to the outlet. You'll have to change the outlet of course to accommodate a normal 110 plug. You can also skip the breaker part and just change the outlet and cap off 1 of the hot wires. Just make sure to kill the power and be safe!
2helpful
I need the instruction manual for a Sears submersible pump model M4D02B-01. I would like to use it to pull water from a lake and about 25 feet in elevation. It is rated at 230 volts but I currently only...
Assuming that your Sears submersible pump Model
M4DO2B-01 can pump water at more than 25 feet
elevation. You can run it even without a manual. Just connect your discharge hose up to the point of discharge. Use a 220/110 volts transformer with a rating of at least 3KVA. Connect your 110 volt line to 110 outlet of the transformer and the submersible pump to 220 outlet of the transformer. This 3KVA transformer can handle up to 1HP pump.Send your
e-mail for further assistance.
Jul 07, 2009 • Plumbing
1helpful
Lionel Trainmaster KW 190 Watt Transformer
The Lionel postwar 190watt transformer is an excellent power supply for trains. If one or more of the binding posts are loose ("U,A,B,C,D" Terminals") you will need to replace the binding post, use a T-159 replacement Binding Post. The original posts are soldered and crimped on.
The T-159 replacement binding post is bolted on. UNPLUG THE TRANSFORMER Carefully pull/pry up the handles and remove them remove the 4 Philips screws on the top, lift off the case top, the binding posts stay with the body of the KW.
Remove the loose bindings post one at a time as needed. Be sure to get any wire reattached. Reverse the procedure to reassemble.
57helpful
10answers
I have had the same problem with my polar express, which i just bought recently. Having to send it to the USA from the UK would be very expensive so i decided to open it up myself. The tamper proof screws were a bit of a problem getting into it. I ground down an old screw driver into the triangle shape to undo them. I then replaced them with self taping srews the same size.
The Problem I found was simple, there is an internal (250V, 8Amp) fuse soldered onto the red wire on the secondary winding of the transformer. The red wire going from the transformer to the PCB, the fuse has black heatshrink over it.
There is no room inside the housing of the controller to fit a fuse holder. I fitted a box on the side of it with a panel mount fuse holder. drilled a hole through the housing, fitted longer red wires, so they could go through to the terminations on the back of the fuse holder.
At least now I can change it simply if it blows again.
hope this is of help to you.
Top Lionel Crafts & Hobbies Experts
ADMIN Andrew
ADMIN Andrew
Tom Chichester
Carolyn Rogers
Are you a Lionel Craft and Hobby Expert? Answer questions, earn points and help others
