Question about ScanSoft PDF Converter Professional (m109a-g00.2.0) for PC
I used the Pencil under Comments/Draw Tools to freehand some writing on my pdf, but the writing is in red and 'd like it in black --- how do I change the color?
Posted by jdwestsongs on
Why does the freehand selection tool keeps releasing before I am ready?
Are you using wireless tools, like a wireless mouse or a wireless pen tool? you better switch of you phone, or better replace it with a wired version. I changed all my beautiful wireless stud, like keyboard and mouse for the same reason.
Jun 19, 2014 | Corel Paint Shop Pro 9
Need a wire diagram for Weller Pes51 50watt Soldering Pencil
http://ptsunow.wordpress.com/2011/06/13/weller-bp860mp-removing-the-button/ I hope this helps
Dec 30, 2012 | Weller Pes51 50watt Soldering Pencil
Problem wit genius mouse pen i608x - i can't draw a line, it's only a dot...
Try updating the drivers at the manufacturer's website. I had the same problem with a similar product.
Aug 30, 2012 | Genius MousePen i608X
I have a Wacom Intuous3 4x5, and I'm not sure if it has pressure sensitivity or not. How can I tell?
Install drivers, open graphics editopr like Photoshop and choose freehand drawing. When you draw and thicknes of line changes with pressure applied then you are sure that it is pressure sensitive.
Mar 17, 2011 | Wacom Intuos3 Graphic Tablet
Pdf
I'm currently using FreeHand 9 and CorelDRAW 11.
> I'm thinking about upgrading to FreeHand MX as I'm really after getting to
> know one tool really well that'll cover most things, print, video and web
> and is multipage!! I've seen all the flak about bugs and the talk of an
> impending update, so I'm aware that there are some issues with MX.
> There's a lot of exciting talk about the new Flash support in FreeHand MX
> but what is the PDF support like? Has it moved on from 9? (What about
> Illustrator support too, since AI now saves as a version of PDF?)
Jan 06, 2011 | Adobe FreeHand MX 11 Upgrade Version for...
I wana put 04 harley hand controls on a 89 harley need wiring diagram
I think the wire colors changed sometime after 2000. If you still have the old controls, you may can make up your own wiring diagram. While you've got the switch housings open to put them on the handlebars, write down what color wires come off of what switch. Do the same with your old switches and your new switchs. If your horn button uses a red and a black wire on your old controls, and your new switch uses a red/white and black wire, then draw your diagram to match the red/white wire where the red wire went.
You're going to have to do a certain amount of this as you will not find a wiring diagram that shows an 89 model bike with 2004 handle bar wiring on it. Good Luck!
Jan 26, 2010 | 2004 Harley Davidson FLSTC - FLSTCI...
How do I use the erase feature in Nuance's PDF
dsmith30 - I am using v 5 but as far as I recall v 4 is the same:
The erase tool only works on lines you have drawn using the "pencil" tool. It does not erase text in a text box.
To use the tool, choose "Comments, then Draw Tools, then eraser" from the menu. Hold the left mouse button while moving it, and it will erase whatever part of the drawn line(s) it passes over.
Michael
Jul 10, 2009 | ScanSoft PDF Converter Professional...
ScanSoft PDF Converter Professional (m109a-g00.2.0) for PC Logo
Top ScanSoft Computers & Internet Experts
Resolution IT Dubai
Resolution IT Dubai
ADMIN Canada
ADMIN Canada
Are you a ScanSoft Computer and Internet Expert? Answer questions, earn points and help others
