SOURCE: tascam pocketstudio5
Hello tasbones and razzledog !I expect the following will help you solving the problems with the pattern file of pocketstudio5 (TASCAM):You need the original CD-ROM which includes the pattern file with many different drums and sound stuff. You have to put these data on a formatted cf-card (everytime again if you will use a new card) !This info comes from a german musician who had the same problem 5 years ago.Try the following Link of TASCAM where you can download the manual, an update and the PATTERN FILE !www.tascam.de --> "Support" --> "download" --> "nicht mehr hergestellte Produkte" --> "pocketstudio5"If this will not work, give me a sign - I will try to send the data to you via mail.freewood/Berlin, Germany
SOURCE: cd rewritable player recorder tascam cdrw4u
I never had that problems. I have been using it over five years. Does it play commercially made CDs (the ones you bought at the store)? Panel shows track numbers and sound volume? Can you hear it by using a head set (phone volume control turned up? If so, now recording part, do you have input select correct (analog or digital)? Input cable(s) into right connector(s)? When you press "record" button, does it put into "pause" mode? Can you watch the incoming sound levels when it is on "pause" mode? Can you start the recording with remote's fader button or play/pause button on the machine? Good luck.
SOURCE: Tascam dr-1 recording problem
There is a "PB Control" button. I had the same problem. You've inadvertently told it to change the speed or something on playback. Make sure that none of the indicators at the top of the screen are active (i.e., white letters on black background). Press the PB Control button to toggle it on/off. Also, any files transferred to a computer will not be affected.
