Expert
- Posted on Jan 12, 2011
Re: My laserjet printer started making load noises and no...
Use the following checklist to ensure that the print cartridge is still operable:
Ensure that the print cartridge is seated properly.
Inspect the print cartridge for remaining toner.
Check the expiration date stamped on the print cartridge box.
Check the print cartridge to see if it has been disassembled or refilled.
Inspect the print cartridge to see if toner is leaking through worn seals.
Check the surface of the photosensitive drum in the print cartridge to see if it has been damaged or scratched. Touching the drum contaminates the photosensitive surface and can cause spotting and image defects.
Blurred areas on printed pages indicate that the photosensitive drum in the print cartridge has been overexposed to light. Because overexposure to light causes permanent damage to the photosensitive drum, the cartridge should be replaced.
The HP LaserJet 1100 series printer cannot print to the edge of the paper, to get the image to fit into this printable area, slightly reduce the size of the image.
try this and let me know, also check the status of the toner.
mail me- [email protected]
