Computers & Internet Logo
Posted on Jan 12, 2011
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
Not able to apply the proxy settings for internet explorer
Lee Hodgson
Level 3:
  • Microsoft Master 4,810 Answers
  • Posted on Jan 12, 2011
Lee Hodgson
Microsoft Master
Level 3:
Answers
4810
Questions
Helped
1801091
Points
15941
Open Microsoft Internet Explorer and from the 'Tools' menu select 'Internet Options'. from the 'tools' menu.
Select the 'Connections' tab.
Select 'LAN Settings'. In the 'Proxy server' section select 'Use a proxy server for LAN ..., enter your proxy address, and enter port 8080. 'Bypass proxy server for local addresses' is selected if you are accessing network resources through a intranet. When complete, select OK twice.
NOTE:
After you apply your settings to the web browser test your Internet connection by attempting to access an external Web site such as http://www.google.com. Test more than one Web site. If you are unable to access external Internet resources, verify the spelling of your entries. If spelling is correct, contact your company's helpdesk to find out if there is a problem with the corporate proxy server.
Regards.
2 Related Answers
Anonymous
  • 2340 Answers
  • Posted on Jan 29, 2011
SOURCE: Neither Internet Explorer or Firefox will connect
Open your Internet Explorer,
Go to Tools -> Internet Options -> Connections "Tab" -> LAN Settings -> Proxy server, uncheck the box -> OK
Restart your Browsers ie IE or Firefox, you don't need the proxy server if your are a home users.
Hope it helps.
Saigua
Steve Nordquist
  • 982 Answers
  • Posted on Feb 14, 2010
SOURCE: Even though Java is installed in my computer, it's
It sounds like you activated a firewall somewhere in there. Calm down and go find out about your proxy server if you were using one in the first place.
Also, what website instructions do you think you followed, anyhow? Lots of websites, lots of instructions...you've given no indication which one you chose.
Proxy server not responding tells my to check my proxy setting what do i do
proxy settings are set in Windows Internet Explorer if that's a windows PC.
1. open internet explorer
2. click on the gear icon in the top right hand corner
3. click "internet options"
4. click "connections" tab
5. click "lan settings"
6. make sure all boxes are unchecked
I can't get my LAN settings to automatically detect settings, box will not check.
Reset your proxy settings
Proxy servers, or proxies, act as intermediary servers between a Web browser and the Internet. According to Microsoft's website, proxies are mainly used by networks in companies to enhance the security and speed of their network connection.
Proxy servers can also be used to log Internet usage, mask the network address of a server or to apply global restrictions to a network.
Internet Explorer is set to automatically detect proxy servers by default.
You can reset the Internet Explorer proxy settings to their default settings from the "Internet Options" configuration.
I have found the easiest way to do this is to add the menu to the top of a webpage.
Create the menu tab on your homepage right click in the top toolbar you should see a number of toolbar options select the menu tab which will add File Edit View Favorites Tools and Help
Click on tools option then from the drop down list Internet Options
Select the "Connections" tab, and click the "LAN Settings" button.
Delete the proxy server address and port from the "Proxy Server" settings and clear the "Use a proxy server for your LAN" check box.
Clear the check box beside the "Automatically detect settings" and "Use automatic configuration script" options in the "Automatic Configuration" section of the "LAN Settings" dialog window. Click "OK."
Click "Apply" and then "OK" to save these changes and close the "Internet Options" dialog window.
Close all Internet Explorer browser windows for these changes to take effect.
http://windows.microsoft.com/en-US/windows-vista/Change-proxy-settings-in-Internet-Explorer
Laptop explorer proxy server automatically jump to 127.0.0.1: 9666, used UltraSurf 2 times
Sounds like Ultrasurf is resetting your proxy settings every time you reboot. Completely uninstall Ultrasurf, using their recommended procedures.
Neither Internet Explorer or Firefox will connect to internet. Firefox say it cant connect to proxy server. How do I check proxy settings?
Hope it helps.
Hello i can't connect to the internet every time i try it comes up saying Error 130 (net::ERR_PROXY_CONNECTION_FAILED): Proxy server connection failed.
This is cause because your computer is trying to connect to a proxy server, Try to remove it and then connect
If your using Internet Explorer click on Tools
- Internet Options
- Connections Tab
- Lan Setting Make sure that all the box are untick
- Click ok and then apply
- Open your Browser
Thanks using Fixya.
1helpful
Whenever i pull up internet explorer it says 'internet explorer cannot display the webpage", my computer says i have excellent connection to my wireless router but my internet is not working
In Internet Explorer, click on 'tools' then 'internet options' then 'connections' then 'LAN settings'. If there is anything checked that has to do with a proxy server, uncheck it and make sure that 'automatically detect settings' is checked. Click 'apply'. Exit out of Internet Explorer. Reopen Internet Explorer and see if it pulls up like normal.
1helpful
2answers
My wireless is working perfectly. But when i click on the Internet Explorer Icon to go on line it says " Internet Explorer Cannot display webpage". So I clicked on "Diagnose Connection Problems". The box...
to: Start > Control Panel > Internet Options > Connections > LAN Settings. Uncheck the "Use a proxy server for you LAN (These settings will not apply to dial-up or VPN connections). !
1helpful
3answers
Please help me with the proxy settings for yahoo messenger
open messenger
click Messenger on top toolbar
go to preferences
select connection
Make proxy settings
click Apply
click OK
_______________+++++++++___________
If you need a software to hide your ip and do Anonymous surfing here's a free proxy software
2answers
Web pages won't load, but internet connection is fine.
Check the Proxy settings in the LAN Connection area.
Here is a document which provides information on the Proxy Settings. You should have NOTHING in the proxy settings. I suspect that you have something that is wrong.
http://technet.microsoft.com/en-us/library/cc817417.aspx
5helpful
"use a proxy server for your lan (These settings will not apply..
I assume you find this in Tools, Internet Options, Connections, LAN. This proxy server setting is only used when you are working through a network at a school or company. You need to have the checkmark next to "automatically detect settings" if you work through most broadband connections like cable or DSL.
Now, if you have the "automatic" checked and the Proxy check appears anyway, this must mean that you have some program that is trying to connect to some network or call home somehow. This could be a virus. Do you have a good AV program? Be careful because many of the websites that say they want to check your system are actually virus downloaders.
Top Microsoft Computers & Internet Experts
Grand Canyon Tech
Grand Canyon Tech
k24674
Are you a Microsoft Computer and Internet Expert? Answer questions, earn points and help others
