Epson Stylus C48 InkJet Printer Logo
Posted on Jan 12, 2011
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
Ink is full but not printing maybe settings ??
Anonymous
Level 3:
  • Master 567 Answers
  • Posted on Jan 12, 2011
Anonymous
Master
Level 3:
Answers
567
Questions
0
Helped
215188
Points
1624
I see that you are facing issues while printing.
There could be two distinct reasons for the same.
Are blank pages coming out of the printer when you print?
If yes, it has to do with the ink, cartridge, alignment, cleaning etc.
If there are no papers coming out, then we need to look at the paper path and error codes.
I suspect you mean that it is the former.
In a bid to resolve that please re-seat the cartridges in the printer once.
Open the door, take them out and put them back in ensuring they "click" into place.
Were the cartridges replaced recently?
Once seated, turn the printer on and perform alignment and force clean the cartridges.
That helps to clean any blocked ink which has dried out.
If this doesn't work for you, please comment and let me know, and I will be happy to assist you to further resolve your issue.
Thank you.
Photosmart ink reset
Maybe it wants ink in the others. I might try putting black in them.
My printer won't print? it has full ink cartridges.How do i fix it?
Maybe your cartridges are not out of ink. Try it with another game cartridge kit...
If I print i.e i print personalised chocolate wrappers the colours are not crisp and stong, they are wish-washy, put ink is full this has only just started to happen
try to adjust the settings of your printer, by the way are you using a replacement ink? if so,, then this is because you are using a low quality ink maybe.
Using Ubuntu, all my docs now come out in full ink
Maybe the solution is to use the LCD control panel on the printer to set the default resolutions to the lowest draft and economy settings and then try printing.
Printer shows i have half full ink,but when i print it prints very light and half way down page there is nothing?
i think there is a prblem about the ink cartridge. the noozle maybe it doesnt flow the ink or maybe you filled the cartridge too much of ink. try a new cartridge cartridge but before that try to clean the noozle of your ink cartridge.. - **wanski cebu**
Printer says "ink is out" when I try to print but it's not
this mean your printer waste pad maybe full and the printer needss to be reset download the ssc and it will reset it for you
Waste ink absorber is full, waste ink full, waste ink absorber, a
may the error code or how many blinking can solve your problem
this is the list of error code
How to clear Error Code Canon printers MP150 MP160
CANNON Printers MP150/MP160 ERROR CODE
E2-2 No paper (ASF)
E3-3 Paper jam
E4 No ink
E5-5 The ink cartridges are not installed or a non-supported ink cartridge is installed ,
or the ink cartridges are not installed properly
E8 Waste ink absorber full, or platen waste ink absorber
full
E9 The connected digital camera / video camera does not support Camera
Direct Printing
E14 The Ink cartridges whose destination are wrong
E15 Ink cartridge is not installed E16 - Ink remaining is unknown
E16 -E19 Failed to scan head alignment sheet
E22 Carriage error
E23 Paper feed error
E24 Purge unit error
E25 ASF(cam) sensor error
E26 Internal temperature rise error
E27 Waste ink absorber full or platen waste ink absorber full
E28 Ink cartridge temperature rise error -
E29 EEPROM error
E33 Paper feed position error
E35 15 USB Host VBUD overcurrent error - USB
E37 17 Abnormal motor driver error
E40 20 Other hardware error
E42 22 Scanner error
try this methode
Methode 1
1) With the printer powered off but connected to a power source, press the Power button while pressing and holding
the Stop/ Reset button.
2) When the Power LED is lit, press the Stop/Reset button two times while pressing and holding the Power button.
3) When releasing the Power button and the Stop / Reset button (regardless of order), the printer will move into a
service mode. (Waiting formenu selection)
4) When the LED lights in green, press the Stop/Reset button the specified number of time(s) according to the
function listed in the table below.(Each time the Stop/Reset button is pressed, the LED
lights alternately in
orange and green, starting with orange.)
The number of the Reset
button pressing
LED Function Remarks
0 time Green Power off
1 time Orange Service pattern print
2 times Green EEPROM print
3 times Orange EEPROM reset
4 times Green Waste ink counter reset See waste ink counter reset
procedures below.
5 times Orange Destination setting See Destination setting
procedures below.
6 times Green Print head deep cleaning
11 times Orange Button / LCD checking
12 or more times Returns to a menu selection
that's all
maybe it can fix your problem
thanks
Printer wont print anything black
hmmm..even on test page, eh? maybe you need a new set of drivers(they get corruped easily).
Top Epson Office Equipment & Supplies Experts
Grand Canyon Tech
Grand Canyon Tech
NH TECH
Level 1 Expert
Are you an Epson Office Equipment and Supply Expert? Answer questions, earn points and help others
