Lay it on its side and lean on it while you're holding the spindle lock button in- if you're right handed lay it on its right side with its back to you. Lay your elbow wherever you can on the handle once you get the button pushed and use your right hand for the wrench. If it's in the position I mention you'll push the wrench down to remove the wheel.
You can heat the center of the wheel, the metal part, to expand it a little.. makes it easier to get off sometimes.
The trick is to put the wheel on properly. Put a little NevrSeize on the spindle threads and screw the wheel on. Don't go picking up the grinder and hitting the switch because that will hammer that wheel on. Just screw it on and tighten fairly firmly.It only has to be tight enough to seat well on the spindle- it only turns one way, so as long as the wheel doesn't come off when it's coasting down it's tight enough.
Wear your safety glasses when grinding, them darn sparks are bad for your eyes.
lp
