Question about Samsung DMR78AHS Builtin Dishwasher
No power no lights samsung dmr78ahs - Samsung DMR78AHS Builtin Dishwasher
Posted by rscotto542 on
  • Troy Whistman Apr 14, 2012
    I had this same problem with my DMR78AHS/XAA. No lights on the display, no buttons worked. Had power to the junction box under the bottom right of the kick panel. Took the screws off the door (torx), and found the computer board. Pulled the power plug (black and white wires) and confirmed I had power there, too (multimeter). Plugged the connector back on, and voila, it worked again. So, before you replace the computer board, try this to reset it. If you do need to buy a new board, I've found Midwest Appliance to have the best price... under $80 when I looked today. http://midwestapplianceparts.com/index.p...
  • Hugh Mar 19, 2013
    same problem here... my DMR78AHS (purchased in Oct.2009) did not have an in-line fuse (las seen in other postings) and i was getting power to the board. Samsung sent a tech out ($90); confirmed it was the board. **NOTE** , Samsumg has a 5-yr warranty on the board (must go through Samsung). So all i have to pay is for the add'l $75 installation fee. CHECK YOU WARRANTIES**
Appliance Guru Gold Coast QLD 4213
    Master:
  • Samsung Master
  • 330 Answers
The electronic computer board is dead & needs to be replaced.
Posted on Jan 12, 2011
mrbond
    New Friend:
Had the same problem. Power at the inlet junction box, but no power at the main board. In my case it was the inline fuse located in the wire loom behind the lower right panel.
Posted on Dec 10, 2012
bert
    New Friend:
Actually the Power Ontrol Board needs to be replaced. It is located in the door. Need to remove screws and put something under door as the panel will drop. Once open you will see the module with all of the wiring connected to it. it took me an hour to replace it.
You can order it from Samsung or , like I did, ordered from Sears Parts. Part DD97-00107A cost was $136.99 & shipping. Best part using Sears Parts is that they have the schematics for the appliance.
Posted on Oct 16, 2011
  • bert Oct 16, 2011
    Actually the Power Control Board needs to be replaced. It is located in the door. Need to remove screws and put something under door as the panel will drop. Once open you will see the module with all of the wiring connected to it. it took me an hour to replace it.
LE ERROR CODE ON MY SAMSUNG DMR78AHS DISHWASHER
this issue relates to a temporary power failure (EG: storm knocking out the power or that a breaker has tripped) this can be fixed by pressing the power key on the dish washer and the error code should clear if not contact samsung for a replacement control board
Feb 23, 2017 | Samsung Dishwashers
How do I fix -no power issue on my samsung dmr78ahs dishwasher?
To eliminate a dishwasher problem, run a heavy 3 pronged extension cord from a known working outlet to the dishwasher and plug the dishwasher into the cord. If you still have no power (dishwasher is not showing any signs of life) then it is a dishwasher problem (circuit board, bad connection from dishwasher cord to dishwasher, etc).
If the dishwasher actually shows signs of life, then you may have a tripped breaker. Check the breaker to make sure it is on and that the tab is not either in the center or the off position. Also, try moving the dishwasher cord's plug from the outlet it is currently in to another outlet in the under sink area. There is a chance that the plug got switched from the normal outlet to the outlet that controls the garbage disposal, that outlet should only be hot when the disposal wall switch is flipped to the on position.
Dec 18, 2014 | Samsung DMR78AHS Builtin Dishwasher
MY BRAND NEW SAMSUNG DISHWASHER HAS POWER BUT WONT START THE WASH THE WASH CYCLE THE TWO CYCLE LIGHTS JUST KEEP BLINKING
What 2 cycle lights? Samsung dishwashers indicate problems and errors by making different lights light up and/or flash. We would need to know the model number too.
If you need further help, reach me via phone at https://www.6ya.com/expert/ronald_e6b9572cebe3ad27
Oct 07, 2014 | Samsung DMR78AHS 6 Cycle Stainless...
Samsung DMT400RHS Leakage error
check you house circuit breakers if you have no lights and the DW is plugged in next check to see that the door switch still locks the DW shut otherwise;call a serviceman
Nov 18, 2013 | Samsung DMR78AHS Builtin Dishwasher
Why does the soap dispenser door does not open to release soap during wash?
I had this problem also with my Samsung Dishwasher if any large dishes were place on the end. It seems to stop the door from opening.
Apr 21, 2013 | Samsung DMR78AHS Builtin Dishwasher
Error code PE on Samsung dishwasher DMR78AHS
I too have the same problem with my dishwasher. Didn't know about the circuit breaker trick. Will give a try. My husband is ready to throw all our Samsung appliances in the trash. We don't recommend them at all. Re-modeled our kitchen 4 years ago and had all new Samsung appliances installed. What a mistake. In the 1st year we had 2 service calls on the dishwasher, 2 on the stove and 1 on the refrigerator. Have had many problems with the dishwasher. Have been in touch with the company but their approach is you bought it your stuck with it. Thanks for the trick to fix PE error code. I'm NOT getting it fixed. I'll use it till I can't use it anymore then go buy something else.
Aug 24, 2012 | Samsung DMR78AHS Builtin Dishwasher
DMR78AHS error code HE
Hi, the HE codes refer to temperature errors. The HE codes refer to heater problems. These are all functional errors that require a certified service technician, but disconnecting the circuit breaker in the meantime can prevent the problem from growing worse.
Jun 13, 2011 | Samsung DMR78AHS Builtin Dishwasher
Heater stays on and melted all dishwasher safe plastic products. Only way to shut off is to pull the circuit breaker.
Sounds like the theromstat is shorted. Download the manual from Samsung before you try to replace.
Jun 01, 2011 | Samsung DMR78AHS Builtin Dishwasher
No power, no lights. Anything I can check befor giving in to a new mother board?
hope u checked with a different smps. First check for power supply , then check for faulty jumper settings on the board, then check the boards power pins .. then replace
Samsung DMR78AHS Builtin Dishwasher Logo
2,349 people viewed this question
Top Samsung Dishwashers Experts
gbob59
Marvin
Marvin
Are you a Samsung Dishwasher Expert? Answer questions, earn points and help others
