According to the user's manual the following procedure is used to set the clock.
Manual is at this link http://www.retrevo.com/support/Pioneer-DEH-P2500-Car-Receivers-manual/id/23227dj392/t/2/
Here's the procedure indicated in the manual
1 Press SOURCE and hold until the unit turns off.
2. Press FUNCTION and hold until the clock appears in the display.
3. Press FUNCTION to select clock.
4. Press the Left Triangle or Right Triangle to select the segment of the clock display you wish to set.
5. Press the Up or Down Triangle button to change the digit up or down.
Hi, if you go to this link you will be able download the product manual for free. to set the clock go to page 29.
http://www.pioneerelectronics.com/pio/pe/vgn/images/portal/cit_11221/50142Operation_manual_DEH-P2500_2002102417744570.pdf
i hope this has helped.
