Check if the blank disc you are using is compatible. It sounds like the discs you are trying to record onto are not compatible with the unit OR you are trying to record in the wrong mode (Synchro v direct see below)
It will only record onto CD-R or CD-RW discs. Also read the instructions for recording as there are a number of recording modes depending on menu settings.
See manual here
http://www.google.co.uk/url?sa=t&source=web&cd=2&sqi=2&ved=0CCMQFjAB&url=http%3A%2F%2Fmedia.zzounds.com%2Fmedia%2FRCDW500C-be7b6d8b3a46898dae1be148e1af5402.pdf&ei=3eIsTcisNI7sOce8hakK&usg=AFQjCNGCxcLKQKViw1TVJPh_baxuXkVKQA
Testimonial: "haveing the correct type of discs helps. cannot use the same data disc from the home computer does not work. had to buy music cd-r. thanks."
