Question about Philips 60P8241 60" Rear Projection Television
I have a phillips 60P8241 rear projection tv. It will not turn on. Sometimes the power light will come all the way on and sometimes the power light will be very dim. Sometimes the power light will not even come on. Even when the power light comes on there is no picture. Tried it a few minutes ago and the power light came on and then the picture came on. Stayed on maybe 10seconds and then turned completely off. Any help would be appreciated. Thanks.
Posted by shauntownsen on
Jim Krause
    President:
  • Philips Master
  • 1,779 Answers
Replace the 12volt regulator on the deflection panel. This ic sets at the back along with 2 other opto's. It is the middle one.
Posted on Jan 11, 2011
I am trying to find the name or part number of the small circuit board that powers my tv off and on model number 60p8241
Hello! Actually that little board is called a ballast. it's not that expensive. It goes fro 60-80 dlls http://www.discount-merchant.com/SearchResults.asp?Search=ballast?Click=48427
Nov 09, 2009 | Philips Magnavox 51MP392H Rear Projection...
PHILLIPS 559401 REAR PROJECTION TV
ok the problem u have is that u need to have a scope and a volt meter to test the circuits what i would do is check and see if u have a 130 v on the horiza output transistor first. but if u dont have any meters there is nothing u can do to fix the problem. and just rember that phillips allwas wonts u to buy the board that is y it is not cheep to repair a magnavox or phillips sometimes u can buy another tv lot cheaper. i hope this help some what marty.
Oct 13, 2008 | Philips 55PP9401 55" Rear Projection...
Sharp 56DR650 shows power but wont turn on, Sometimes it turns on
That's error code 32. Indicates lamp trouble or failure. The system will shut down automatically.
Aug 29, 2008 | Sharp 56DR650 56" Rear Projection HDTV
Phillips Magnavox 9P6031C103
You can try ebay, they may have them for auction. or you can try the vendor (philips).
I hope this helps
Shuttle83
Jul 07, 2008 | Philips Magnavox 9P6034C 60" Rear...
Power Problem (Phillips 55P8341 Projection TV)
Same problem... I pulled out the second electronic board going from right to left and see a burned diode at position 3307. I wanted to know if anyone has a schematic of this TV and could tell me the numeric value of the part in position 3307. It would be appreciated it you could let me know.Thanks...
May 30, 2008 | Philips 55P8341 55" Rear Projection...
Sony 65 inch rear projection
I just have fixed one just like this i replaced relay and 47uf cap next to relay, this fixed the sony, like yours it would sometimes come on and play 3 days with no problem then turn around and set would not come on. ThankYou for trying FixYa. Have a Nice Day.
Feb 19, 2008 | Sony KP-65WS500 65" Rear Projection...
Phillips Magnavox Rear Projection Tv screen too dark
The high voltage is failing. The LSB board is about $200 from partstore.com.
Dec 28, 2007 | Philips Magnavox 51MP392H Rear Projection...
62inch phillips bigscreen tv
how many times does the power light blink, that can be an error code indicating whats causeing the set to not start. Let me know how many blinks its blinking and also let me know your model number.
Dec 07, 2007 | Toshiba 43H70 43" Rear Projection...
Tv turns off by itself sometimes
have a tech repair your tv.good luck let him look at the power supply or the related cirucits.good luck
May 14, 2007 | Mitsubishi VS-45607 45" Rear Projection...
Philips 60P8241 60" Rear Projection Television Logo
Top Philips Televison & Video Experts
Demonic-2011
Demonic-2011
Are you a Philips Televison and Video Expert? Answer questions, earn points and help others
