your problem is air in the system.
you need a pressure test to make sure there are no leaks.
than have your radiator flushed.that will fix your problem if there are no leaks.
good luck
Pls check the thermostat. It is most likely a sticking or even stucked as that is basically its
purpose, to restrict the coolant flow and allow the engine to reach
operating temperature thereafter grant free flow of the coolant. It
would seem that there is considerable delay in its opening and
therefore the temperature rises above the normal operating temperature.
Hope this be of initial help/idea. Pls post back how things turned up or should you need additional information.
Good luck and kind regards.
Thank you for using FixYa.
Overheating can be extremely bad for a car. Back in the days of carburetors, when engines were made of steel, overheating was much more common, and less damaging. But the modern engine has far less tolerance, with its aluminum blocks and, often, aluminum heads.
Many head gaskets have been blown out by overheat issues. Many heads have been cracked. These are not cheap repairs. Therefore, be vigilant and watch that heat gauge (thermometer). If your car starts to overheat, pull to the side of the road, and let it idle (do not give it a fast idle - that only worked in the days before electric fans) and, if that does not seem to be working, shut it off.
Bohdan Bodnar wrote: "The 2.2/2.5 liter cooling systems *MUST* be purged of air before operation; otherwise, coolant flow blockage will result (i.e., hot, possibly REALLY hot, engine). Partial purging will cause the engine to run hotter than normal; the temperature will gradually drop to normal as the system purges itself over several days/weeks."
For car running hot and overheating issues, I suggest to you go through this help links.
Click this link below and go through the troubleshooting procedure to take care of the problems: ----
Car runs hot?
http://howtobyme.blogspot.com/2011/11/car-runs-hot-in-traffic.html
All types of car overheating problems and troubleshooting?
http://technoanswers.blogspot.com/2011/11/all-types-of-car-overheating-problems.html
Car freeze overnight and started overheating while driving?
http://technoanswers.blogspot.com/2012/01/car-freeze-overnight-and-started.html
Engine Overheats and heater blowing cold?
http://howtobyme.blogspot.com/2011/11/engine-overheats-and-heater-blowing.html
Car overheats and Air blows hot at idle?
http://howtobyme.blogspot.com/2011/11/car-overheats-and-air-blows-hot-at-idle.html
overheating?
http://schematicsdiagram.blogspot.com/2011/12/buick-century-overheating.html
Car engine Overheats and transmission starts slipping?
http://schematicsdiagram.blogspot.com/2011/12/car-engine-overheats-and-transmission.html
----------This details will help.Thanks.
Car runs hot?
overheating?
where is the drain located on the PT Cruiser
Seems to happen only when I am idling for some time, such as at a light, or stop and go traffic on the freeway
I also have a 2002 PT Cruiser, for only the last 3 months, and I, too, have been plagued with this overheating problem! I have had it in with it's "warranty" 2 different times, both not showing anything wrong with this overheating problem. EVERYTHING was checked, problems with the A/C, Heating, anything else they could think of! I left, with a list of things to "try" to get the problem to return! Nothing I did worked, but after a trip 4 hours out of town, it overheated 3-4 times with my husband driving! Each time we were just idling! And last night, with my husband in the car, it overheated again, this time smelling antifreeze, and we drove straight to the dealership where we purchased it!
We were told the next time it happened, we were to go directly there and have them see it! Of course, no one but the 3rd shift mechanic was there, but he was a gem! He tried several things and after about an hour, he found that it was the cooling fan for the radiator NOT WORKING AT ALL and it had to be replaced! I left it there for the shop to fix today and I will be able to pick it up before they close this afternoon! So, PLEASE check this out! It happens all of the sudden and you will have many more problems arise from it, if you haven't gotten it fixed yet! Hope this helps. Now, I just need to find out how I get my "loss of air" in my front tires fixed! They've had it 2 times, each cleaning the aluminum rims and rebeading the tires. I STILL have 12-16 lbs. of air to replace every 3-4 days, in my front tires! This is ridiculous and I refuse to just accept "It's what happens to a PT Cruiser's front wheels"! I've even had a mechanic tell me that he owned one a while back and the loss of air in one of his front tires was the problem in an accident he had! Unbelievable! Let me know what happens! Linda :)
Same Problem with my 2002 Pt Cruiser. I replaced the Cooling Fan Motor, Coolant sensor, Thermostat, Radiator cap, and Coolant. It still overheats when the Air Conditioning is turned on only?????
I just got a 2005 pt a couple of weeks ago with 137,000 mi. It has overheated twice with the past week. I noticed the idle is rough when I have the front defroster on, and tonight i noticed some sort of small puddle under the front part of the car. I'm trying to narrow down the possible suspects: thermostat, water pump?
I have a 2002 pt had the head gasket replaced the water pump timing belt thermostat and radiator cap car still overheated so I replaced the fan relays high and low also the fan still overheating should I junk the car
I am currently dealing with this same problem. It over heats only when idling. I had the radiator rotted out and that didn't fix it. Then I had a thermostat put in and that didn't fix it. Now the mechanic said he notices that the fan is not always coming on when it gets hot but the fan does work some of the time. So now he wants to put a new coolant sensor in and see if there is a problem with the grounding of the fan. Does anyone have any advise as to why a fan would only work some of the time?
