Question about Canon LaserClass 9000L Plain Paper Fax
Canon Laser Fax 9000 needed to replace toner, did so, and now the fax acts as though I did not change it and the alarm keeps going off, a few minutes after re-install. Should I unplug it?
Posted by pbarrett546 on
George Mclaughlin
    Sergeant:
    Champion:
  • Canon Expert
  • 370 Answers
Find the package that the toner came in. It will have directions inside on how to reset the toner alarm.
Posted on Jan 11, 2011
Paper jam 2 but no paper is stuck
Most printers/faxes need more than one or two sheets of paper in the hopper in order for printing to commence. If it's not that, take out all paper. Turn off the printer/fax. Wait five minutes and turn printer/fax back on. With some printers/faxes, that almost acts like a re-boot. Good luck!
My printer states "Check printer"
The "Check Printer" error can usually be cleared by unpluging the fax from the wall outlet, waiting a few minutes, and then plugging it back in. If the fax is connected to a UPS, or multioutlet strip, it is highly recommened to plug it directly into the AC wall outlet.
If the message stays in the display, try opening and closing all the access doors to the fax. If that still doesn't return the machine to operating properly, then you will probably need to take it to your service provider.
Hi i really need to recieve a fax, but it says the toner life is done, is there anyway to squeez one more fax out of it?
dip the toner in a mild hot water for few minutes and replace it after wiping . you will find that you have some ink its the coagulated ink within the cartridge. it works i have tried.
23helpful
2answers
Panasonic KX-FL512 fax drum life error
You need to follow the instructions that came with the drum as you need to reset the internal counter.
All recieved faxes going straight to memory
Either it needs toner/drum unit replaced or it's hungry for paper....is it displaying an error code?
1helpful
Canon Fax L100 - toner required even though not empty
hi
first do use the original toner if no use the original toner if yes check the toner cartridge may could be brocken ore the toner jammed on it if its ok you have to check the toner sensor that located in side the fax m/c under the toner cartridge may its came out of position .
thanks
Keep saying change cartridge
Yes i found one spring was out of its place it is near the paper feed assembly.
After placing the spring in its hinges the problem was solved.
Canon CFX-L4000 not receing faxes.
##322 is the fuser unit under the cart that needs to be replaced!Good Luck!
2answers
Keep Adding Toner to Panasonic KX-FL511
kindly follow this instruction
but doing this will erase all the message in the memory
press menu #9000*550 start
unplug the unit once heard the beep
after 10 seconds, plug it again
Canon LaserClass 9000L Plain Paper Fax Logo
old marine
old marine
Ekse
