Cameras Logo
Question about Toshiba Cameras
I'm having a problem with an NB 205 netbook. The battery will not charge with the AC adapter plugged in, and more annoyingly, will not use the AC power instead of the battery unless the battery is physically removed. Symptoms and specs are as follows: - Toshiba netbook NB 205-311, windows xp home SP3, 1GB ram - With the computer off and the adapter plugged in the green AC power light comes on and the yellow battery light slowly turns on and off. I left it like this overnight and the battery has gained no charge. - With the computer on when you plug in the adapter the computer recognizes the adapter for a moment, then goes back to battery, then recognizes the AC power again for a few seconds, then finally reverts to battery and stays there. Unplugging and replugging the AC adapter produces the same on/off/on/off cycle each time. - With the battery physically removed the computer works fine with the AC adapter.
Posted by zen7_kelvin_ on
Tony Parsons
  • Toshiba Master
  • 6,402 Answers
As you yourself have said, this is NOT a camera. For help, I would advise you to post this in a forum dealing with computer equipment.
Posted on Mar 10, 2017
Acer netbook died
Try a different charger/AC adapter. The battery may bot be charging and the adapter may not be working and not able to power the machine.
Btw, I’m available to help over the phone in case u need at https://www.6ya.com/expert/dave_fb2c45146b845cea
Acer Ferrari ONE 200 wont power up
you have to check that your battery is charging or not in your laptop by another laptop or battery,if problem is not solved,then check battery port
My msi netbook wont turn on even though the battery charging indicator is lit.
1. Turn netebook OFF with button, hold 4 seconds.
2. Remove recharge plug
3. Remove battery
4. Leave it like this for about 5 minutes.
5. Put everything back and power the laptop again
Does it appear to charge the battery at all when plugged into AC? Can you hear the charger humming when you put the brick up to your ear? (while it's plugged into AC,You may have a bad motherboard
1helpful
My HP Mini Netbook will not turn on and the battery will not charge.
Perhaps your AC Adapter is bad. That is the cable that plugs into the wall and then into your laptop to charge it. Take the laptop into your local computer repair shop to see if they have a used replacement, or a Universal Laptop charger. We sell them at my store. www.ravencomputers.com. If you can't find one, go to our website and either email us or call us and let us know, we can ship anywhere in the US. If you try another AC Adapter and it still won't charge, then most likely your battery is bad. You can also try pulling the battery out and trying to turn it on with just the AC Adapter plugged in. If that works, then you know the battery is bad.
I've had Toshiba Netbook NB-205 for a year, and the display won't show. The fan will come on for a like two seconds and then cut off. If I need to replace the fan, then I'm fine with that, but if there's...
Try removing the battery and starting it up with only AC power.
Sometimes it doesn't charge properly and will turn off after a second. Removing the battery will sometimes fix this.
Make sure you are getting charge lights as well. If the AC adapter isn't working anymore, it can cause exactly what you're experiencing.
Please leave feedback if you found this helpful. Thanks.
2helpful
3answers
I bot a hp mini laptop recently.. ws working well..bt sddnly it ws nt chrgng ystrday and showed cross sign over battery in control panel.. why is it nt chrgn and wht to do?
If the laptop is still working when it is plugged in , then the ac adapter is good and the battery is just bad. If the laptop will not work when it is plugged in then more than likely the ac adapter is bad.
Need a keyboard removal guide for Toshiba netbook nb-205-n230
If you need to ask "how", I recommend that you STOP, and take the computer to a qualified technician, who can safely and correctly repair your computer.
2answers
My hp pavillion was no power, please give an advise.
There could be a problem with the battery. A fast check to determine whether you have a problem with the power adapter, power cord or the laptop's battery is to turn off the laptop, remove the battery, connect the power adapter, turn on the laptop & see if it works.
If the laptop works directly from the power adapter with the battery removed, then the power adapter is good. In this case we can suspect that the battery is defective & needs to be replaced.
To verify this, unplug your laptop & try to run it on battery only. Watch out how long it will stay on (if at all). If it didn't work on battery alone, or worked but for a very short time, then your battery is defective.
Cant on my pc and no display appear at all
Unplug AC adapter from power cord, remove the battery wait 30 min, put back battery and plug the AC adapter.If not charging the battery, the problem is in AC adapter.If laptop not turn on need service.If it's in warranty contact service in your are.
Top Toshiba Cameras Experts
ADMIN Andrew
ADMIN Andrew
Tony Parsons
Tony Parsons
ADMIN Eric
ADMIN Eric
Are you a Toshiba Camera Expert? Answer questions, earn points and help others
