Question about Haier BC112G Wine Cooler
I have a Haier BC112G wine cooler and I need to find out where I can find a product manual online
Anonymous
    New Friend:
  • 135 Answers
I have a Haier BC112G. It is not cooling at all. Temp panel works, so I can set the thermostat up or down, but nothing happens and it just goes back to room temp after that.
Our magic chef wine cooler (mcwc50dbt) when temp is set on digital panel at 45-50 it jumps immediately back to 70 degrees constantly
Sep 25, 2013 | Haier BC112G Wine Cooler
Need Haier thermal electric wine cooler manual:Model #HVTS18DBVS serial #o90800187 Would appreciate info.
You could try
operatingguides.com
if you need a user manual
or
servicemanuals.co.uk
if you want the schematics etc
We've used them in the past and found them very good.
Also if it is not listed then ask via the link and they
will probably be able to get it for you.
Jul 13, 2011 | Haier BC112G Wine Cooler
Cooler constantly runs
It sounds like it could be a thermostat problem. If it is a faulty thermostat, you will have to replace it as it will burn out the motor (compressor).
http://www.google.ca/search?hl=en&safe=off&client=firefox-a&hs=DMy&rls=org.mozilla%3Aen-US%3Aofficial&q=Haier+BC112G+Wine+Cooler+thermostat&aq=f&aqi=&aql=&oq=
May 27, 2011 | Haier BC112G Wine Cooler
NEEDED: manual for BC 112G wine cooler
Hello Ahanaples,
I understand that you are trying to locate a user manual for you Haier BC112G wine coller. I have located the manual on Haier.com the following link will take you to the page then you just have to click on the model of the unit that you have the first one at the top of the page.
http://www.haieramerica.com/en/support/modelsearch
Thank you for choosing FixYa.com
Justin Burnett
Mar 28, 2011 | Haier BC112G Wine Cooler
Wine temp on Haier wine cooler BC112G went to LL, opened up and some champagnes frozen, other wines very cold, condensation all over door, how do you fix this error?
The error is likely caused by a bad temperature sensor. The control board may still be Okay.
Replacing both of them is recommended.
Check this link for parts: http://www.partstore.com/Model/HAIER+AMERICA+TRADING/Haier/BC112G.aspx
Dec 31, 2010 | Haier BC112G Wine Cooler
Power surge caused wine cooler to quit cooling
Power surges, spike and brown-outs are a nemesis to small refrigeration units. The capacitor for the compressor likey was affected and possibly the start components in general, especially if the unit was operating when the surge occured.
Jul 20, 2010 | Haier BC112G Wine Cooler
Are red wines stored on the top or bottom of the Haier BC112G wine cooler? How about white wine? Have lost my owners manual and don't know where to put red wine when the temp is set cooler for white wine
http://www.haieramerica.com/en/asset/archived/BC112G.pdf
is the link to your manual.Typically in a dual temperature zone wine cooler whites are stored in the bottom and reds on top as whites are better a little colder and the cold air will drop to the bottom of the unit.
Hope this helps!
Jun 14, 2010 | Haier BC112G Wine Cooler
Haier BC112G wine coere is an apparent spill that
you will have to gently pry it all around with a thin scraper, i am assuming there is no sealer as fluid would not have leaked in if there was.be gentle but forceful.
Oct 17, 2009 | Haier BC112G Wine Cooler
Haier wine cooler
Haier BC112G service & user manual:
To adjust the temp of your unit:
  • Push & hold the red wine & white wine button at the same time.This will start the temp adjust. You will notice the plus sign & the negative sign on these same buttons, use them to adjust temp. When you are done hit the light button & it will record the new temp.
Nov 25, 2007 | Haier BC112G Wine Cooler
Haier BC112G Wine Cooler Beeping and overcooling
That thing that's beeping...it is the circuit board. It is telling you that it wants a new cousin to live in your house. Replace it.
Oct 28, 2007 | Haier BC112G Wine Cooler
Haier BC112G Wine Cooler Logo
857 people viewed this question
Top Haier Furniture Experts
Colin Stickland
Colin Stickland
Dennis Boxerman
john h
Are you a Haier Furniture Expert? Answer questions, earn points and help others
