Question about JVC LT-32P679 32 in. LCD TV
Hello ! I have a JVC 32" LCD TV which I bought a couple of years ago from Argos, its been doing great but one fine night it shut it off normally and since next morning it had not turned on there is no LCD light, nothing can you tell what can be the problem and how much will it cost to fix many thanks Munam
Posted by munam_81 on
Keith Poitier
    Filmmaker:
    Uploaded 5 video answers.
    New Friend:
  • 106 Answers
Look inside for a blown fuse.
Posted on Nov 25, 2011
Hello! I bought a LG 32-inch LCD (32 inch )
My best advice would be to call out your LG service repair engineer, it is most likely the current software in the TV is of an older version & will need to be re-programmed which an engineer should be able to check. This should cure the menu problem.
Mar 21, 2010 | LG Televison & Video
LG HDMI problem
have you found the solution for this problem because i have the some problem with my tv??
Oct 07, 2009 | LG 32LG30 32 in. LCD HDTV
Jvc lcd tv
Without seeing the lines in question, it is difficult to say 100%. But, if the panel was cracked, the only remedy is to replace the panel. Given its age (3 months), unless there is specific evidence of impact, I would suggest that the crack may have come from the frame moving with time. Don't waste your time with the local shop. Call JVC directly and indicate that you had no impact on the TV and that the "shop" is trying to not repair it. Verify that the TV has the same problem as when you brought it to the shop.
Dan
Sep 25, 2008 | JVC LT-32X887 32 in. HDTV LCD Television
JVC i art 32" flat screen
Does anyone know where can I buy a screen for a 27" LCD Insignia TV. Model is NS-27LCD? My screen creaked. I checked out e-bay and have not found a broken TV with a good screen. Does anyone know where I can buy a screen at.
Thank you all for you time.
JC
Jul 22, 2008 | Televison & Video
Wharfedale TV power problems
got a 32 inch wharfedale tv from argos also and it seems to boot up and then shut down and just loops, if i keep unplugging it i can sometimes get it on but with a high pitch wailing, only 15 months old, gutted!
Jun 16, 2008 | Televison & Video
32 in ilo tv not turning on
The power supply most likely failed on your TV.
I service these power supplies.
Let me know if you need further assistance. my email is [email protected]
May 20, 2008 | iLO 3200 32 in. LCD Television
Akai LCT3201AD 32 in. LCD picture stretched around the corners
This set has several differant aspect ratios, could you have unwittingly change it to a zoom or expand by mistake?
Feb 07, 2008 | Akai LCT3201TD 32 in. LCD Television
32 in RCA MODEL NUMBER f32650
TV FINE UNTIL 2 NIGHTS AGO HAVE HAD 4 YEARS, STARTED HAVING A FOGGY SCREEN WITH WHITE HORIZONTAL LINES. HAS SOUND A FOGGY SCREEN WITH WHITE HORIZONTAL LINES. called retrace lines please check 1 screen control on eht transformer is mituned 2 supply to screen of crt 3 supply to rgb video output is absent 4 connector loose 5 crt base loose thanks
Sep 11, 2007 | RCA F32650 32" TV
Westinghouse 32 in LCD TV
I have had this problem now for about six months with my Niko OPT-3211W. After replacing the Inverter card, VIT70002.00 as suggested nothing changed. I then read that it may be a couple of capacitors in the power supply, but I do not have the skills needed to replace them, nor do I want to pay to fix it. The solution is simple... turn on the TV and wait two to five minutes, then turn off the main power. I suggest using a power strip. Then turn the power back on in two to five seconds. The TV will come back on and it works great from then on. I thought that it was a freak thing, but it keeps working.
Jun 10, 2007 | Westinghouse LTV-32w4 32.02 in. LCD HDTV
JVC LT-32P679 32 in. LCD TV Logo
Top JVC Televison & Video Experts
Demonic-2011
Demonic-2011
Are you a JVC Televison and Video Expert? Answer questions, earn points and help others
