The C330 uses MMC and SD cards. Your 4GB card is actually an SDHC card. While SDHC cards will fit into SD slots, they are electronically incompatible and won't work. You need to go with cards 2GB and smaller.
I have 2 GB SD Card but when i try to use in my Kodak C330 its showing Memory Full. When I format it then it shows FILESYS Error e001000 message. please resolve it
Error e00100 means that the card is corrupted or formatted for another
digital camera.Format memory card and see the results,Try to format the memory card using a card reader with the PC, if error still exists then it means the memory card is electronically incompatible and won't workThe Kodak C310 uses MMC and SD cards and may be you are using SDHC memory card, In this case change the memory card, I hope problem will be solved, if error still exists then contact to Kodak Cameras service providers.
I hope this solution helps you Your token of appreciation in the form of Four thumbs and testimonial will be esteemed. THANK YOU and Keep Visiting FixYa!
Use a card reader and format on a PC. When card is inserted go to my computer and the disc should be there, right click and go to format then proceed as per screen instruction.
if you already try to fromat the memory card into the camera and there's an error come.try to format your memory card from your computer if you have card reader.if the problem still occur you memory card have a problem and you need to buy new one.
Hi there Check to make sure the cards write protect is
off, take the card out of the camera, face the card towards you, look
for a small white tab on
the left hand side of the card, to unlock it push the tab down, it will
be at the side of the card like this . Put it back in the camera and use the menu to format the card. If the format fails then its a possibility that you will need a new card.
But try an firmware upgrade. Maybe the supporting now the 2 GB memory cards.
Why download firmware version 1.07? This firmware version improves memory card compatibility and provides general performance updates. KODAK EASYSHARE C330 Zoom Digital Camera Firmware
Insert your memory card into your computer's reader if you have one. If
not, you can purchase a multi-format USB Memory Card reader from
Amazon.com or Buy.com
Open up 'My Computer'. You should see it under the list of available
drives.
Check its contents first to make sure that you have the right drive.
In 'My Computer', right-click on the drive and choose 'Format'.
5
Leave all the options as they are and click on 'Start'. This is a
non-reversible process so make sure this is what you truly wanted to do
in the first place.
6
Once the process is completed, take the memory card out and insert it
into your Digital Camera or any other device. Try to browse to it to
make sure it works fine now.
