Question about Ecoquest Fresh Air Air Purifier
My freshair 2.0 turns on and right back off. the screen lights up and then goes out.
Anonymous
    Novelist:
  • 74 Answers
The most common reason for surging or changing power levels is a loose connection somewhere.
1) Make sure the plug in the back is inserted firmly and the wall socket is live. The wall socket should not be powering a high-use appliance such as a furnace or refrigerator.
2) Make sure the plate is inserted firmly and correctly in the top and bottom "tracks" inside the machine. The metal contact fingers should be pressing firmly and evenly on both sides of the plate, in the metal screen area.
3) Inspect the interior of the machine, looking for loose wires, corroded clips, any broken wires or connections. (You or a handy friend may be able to repair the loose wires or clips; it's a pretty basic fix.)
If none of these troubleshooting steps solve the problem, the problem may be in the computerized system. For that, you'll need to get in touch with Vollara (formerly EcoQuest) customer service. 800-989-2299.
Posted on Feb 12, 2011
Ecoquest freshair - inside wireing
Black = phase white = Neutral , Strip yellow/green =ground
Aug 11, 2008 | Ecoquest Flair Air Purifier
Where is fuse for ecoquest freshaire
Mine is on the back, just above the pluggin for the cord .
The fuse may be accessed by unplugging the cord from the back of the unit and gently pulling the fuse holder stright out. 100 & 110 volt models use 1.6 Amp slow blow fuse.
220/240 volt models use 1.0 Amp slow blow fuse. Got this info from my owners manual. I would also check to see if the on/off switch in on, this is just above the fuse. I hope this helped.
Feb 02, 2013 | Ecoquest Fresh Air Air Purifier
How do you replace the bulb in a freshair purifier
Make sure you have the starter use with replacement bulb. Usually comes with replacement bulb. Open the back of th unit by removing the cover.
Oct 18, 2012 | Ecoquest Fresh Air Air Purifier
How do you replace batteries in freshair remote control . i cant get the back off the remote control.
For the Fresh Air 2.0 or 2.1 remote, its oval shaped.
1. Hold the remote so that that the power button is facing up.
2. Then flip the remote in your hand so you can see the back side.
3. Then with your other hand, side your index finger from the top down the back side of the remote until you finger nail catches the a slot (about an inch from the top of the remote). Right below that slot, is a plastic tab that secures the battery cover. Using your finger nail, pull that tab down about 1/16" away from the remote to unlatch the cover.
4. Lift the cover off the remote, and you should see 2 AAA batteries. Remove the old batteries and replace with 2 new batteries.
5. Align the two tabs on the battery cover into slots on the back of the remote.
6. Gently press the back cover and the latching tab should shap into the remote.
Hope this helps.
Jun 14, 2010 | Ecoquest Fresh Air Air Purifier
I need to replace back cover
Call EcoQuest 1-800-989-2299 to order the part.
Jul 05, 2009 | Ecoquest Fresh Air Air Purifier
I need replacement parts for my FreshAir. Lamp
E mail to [email protected] List the parts you need and the serial number. They'll be glad to help you!
Mar 31, 2009 | Ecoquest Fresh Air Air Purifier
Away mode broke my fresh air by ecoquest
There could be a couple issues at play here.
1) The power cable might not be plugged in correctly.
2) The fuse might be blown
3) there might be another electronic failure.
1 and 2 are pretty easy to check. Go to www.healthylivingia.com and look for the FreshAir, under the support tab you will find manuals that you can print out.
For the third option you would have to send it in. An authorized repair center needs to take a look at the machine and diagnose the problem. You can call EcoQuest at 1-800-989-2299 to find out where the closest repair center is.
I hope this helps.
Eric
Dec 28, 2008 | Ecoquest Fresh Air Living Air Purifier
Ecoquest Freshair unit; fan is intermittent.
Hi Susan,
I have not experienced it but I know that if you bought your FreshAir from a dealer with EcoQuest you are entitled to a 3 year warranty.
Contact the manufacturer EcoQuest at 1-800-989-2299 and choose technical assistance from the menu. You will be guided through some trouble shooting and if needed you will get an RMA number so you can send your unit in for repair.
If you are not in contact with your EcoQuest dealer anymore and the unit has never been registered with the company you need a purchase receipt with the date on it.
Hope this helps!
Eric
Dec 02, 2008 | Ecoquest Fresh Air Living Air Purifier
Ecoquest FreshAir - UV Flickering
UV bulbs, or rather the RCI cell needs to be changed every three years in the FreshAir, or when the "Replace RCI cell" appears, whichever comes first. The UV bulb loses its intensity over this period of time.
Eric
Download PDF Manual
Feb 17, 2008 | Ecoquest Fresh Air Air Purifier
Ecoquest Fresh Air Air Purifier Logo
Top Ecoquest Air Purifiers Experts
Dan Webster
Dan Webster
john h
Are you an Ecoquest Air Purifier Expert? Answer questions, earn points and help others
